Schaublin 125-CNC retrofit.
5 years 8 months ago #200457 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Hi Tom,
No there are no glass scale encoders on there...yet :)
Mark
5 years 8 months ago #200458 by RotarySMP
There is a 125CNC here with the starwheel tailstock
Reading around, the 2-speed star-wheel Schaublin tailstock appears to be very desirable.
My mate Jörg, who helped unload and drag it into the garage has a 125-CCN, the later model with the Fanuc controller. He has one of those star wheel tail stocks in his. I guess the pneumatic tail stock was not that popular, s all the later ones I have seen have the star wheel one. I plan to borrow Jörgs tail stock and copy it.
Mark.
5 years 8 months ago #200459 by RotarySMP
trilobyte wrote: Hi Mark
i would take the old stuff out. i would spend new motors and drivers to the machine. i mounted 3phase berger lahr stepper with leadshine drivers. these are ok, but max speed is 1500mm/min.
i may update to ac servos. the tool change takes tooo long with this 1500mm/min. 6000 would be nice!
the new elp series of leadshine would maybe a good choice?
www.leadshine.com/ProductSubType.aspx?ty...tage-ac-servo-drives
peter
Thanks for the feedback Peter. For those who dont know, Peter has the same 125-CNC, or a slightly earlier model with the gear train xis drive. I will be trying to copy his shoe horning of everything into the Pneumatics compartment, to delete the E-cabinet.
Mark
5 years 8 months ago #200512 by db1981
Replied by db1981 on topic Schaublin 125-CNC retrofit.
What size are the actually mounted servos?
flange, shaft, holding torque, rpm ?
5 years 8 months ago #200515 by RotarySMP
I still need to pull one and measure it. Unfortunately there is no documentation on the electrical characteristics.
Mark
5 years 8 months ago - 5 years 8 months ago #200526 by anfänger
Replied by anfänger on topic Schaublin 125-CNC retrofit.
if you are lucky it‘s on the servos them self. And your machine is so clean that you can read it. On my machine I had some places where I couldn’t read anything before cleaning and I clean the letters off together with the grime :D
Last edit: 5 years 8 months ago by anfänger.
Time to create page: 0.223 seconds
