Schaublin 125-CNC retrofit.
5 years 7 months ago #201350 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Thanks, save €65 verse butcher 4 Cat 6 cables, pretty good deal, thanks.
Just wondering, by why not just put RJ45 sockets on all the boards which have RS-422 ports? They'd be cheaper than the plug in screw connections, easier to to fab, and easier for the user to integrate.
Mark
5 years 7 months ago #201351 by J Green
Replied by J Green on topic Schaublin 125-CNC retrofit.
Mark
Yes , I watched many of his casting videos some of which show details about his electric melting furnace construction . ( electric heating coil type furnaces tend to burn out quickly at cast iron temperatures )
Anyway, his video included a section of his vacuum pump which I thought might be interesting to you . As I was watching his Lost Foam technique wondered if 3D printing a female mould an then fill it with foam in a can insulation stuff could work for making lost foam patterns .
Break time is over - back to the Schaublin 125-CNC retrofit.
Bob
5 years 7 months ago - 5 years 7 months ago #201353 by PCW
Replied by PCW on topic Schaublin 125-CNC retrofit.
RotarySMP wrote: Thanks, save €65 verse butcher 4 Cat 6 cables, pretty good deal, thanks.
Mark
I do have them on some boards but sometimes these connections are used for other purposes
(non-sserial devices so a straight through cable could not be used anyway)
The connector cost is about the same
BTW you would only "butcher" 2 cables ( by cutting them in 1/2 )
Last edit: 5 years 7 months ago by PCW.
5 years 7 months ago #201365 by tommylight
Replied by tommylight on topic Schaublin 125-CNC retrofit.
To prevent people like me plugging in the network cable and wondering why there is no link to starlink satellites! :P
The following user(s) said Thank You: DoWerna
5 years 7 months ago #201380 by RotarySMP
PCW wrote: BTW you would only "butcher" 2 cables ( by cutting them in 1/2 )
You know I would have been dumb enough to buy 4 short cables, rather than two longer ones. :-/
Mark
5 years 7 months ago #201386 by PCW
I cut a few connectors off the ends of patch cables before the light bulb went on...
Time to create page: 2.938 seconds
