- Thank you received: 24
Schaublin 125-CNC retrofit.
- J Green
5 years 7 months ago - 5 years 7 months ago #201309
by J Green
Replied by J Green on topic Schaublin 125-CNC retrofit.
Mark Are you considering future servo driven Live Tooling on the extra turret , that all us viewers are going to want ?
Thin wall 1/16 inch casting and cheap vacuum accessory
Last edit: 5 years 7 months ago by J Green.
- RotarySMP
- Thank you received: 595
5 years 7 months ago #201316
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Wonder how I missed the 7i83?
- Thank you received: 5334
5 years 7 months ago - 5 years 7 months ago #201320
Replied by PCW on topic Schaublin 125-CNC retrofit.
You still need the encoder inputs
One possibility is a 7I92+ 7I85 +7I83
Last edit: 5 years 7 months ago by PCW.
- RotarySMP
5 years 7 months ago #201326
by RotarySMP
Why the 7i92, if only using SS daughter cards, the 7i94 would be a better fit wouldn't it, or is there no LinuxCNC HM2 driver support for it?
7i94 - Brain
7i83 - Analog motors
7i84 - IO
7i85 - Encoders
7i73 - Control module.
That set pretty much duplicates while a liitle cheaper than 7i97/7i74/7i73/7i84 with a smaller footprint, if I can make up something to stack the 7i94, 7i83/7i84/i85 vertically if the space gets too tight.
7i94 - Brain
7i84 - IO
7i85 - Encoders
- RotarySMP
5 years 7 months ago #201327
by RotarySMP
Bob, did you watch his follow on video with the motor cooling fins? Excellent.
5 years 7 months ago #201335
The 7I85 already has 5 sserial channels so a 7I92 is a bit cheaper
The following user(s) said Thank You: RotarySMP, J Green
Time to create page: 3.117 seconds
