- Thank you received: 139
Schaublin 125-CNC retrofit.
- smc.collins
3 years 2 months ago #277656
by smc.collins
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
that's a nifty little program, I'm curious to see how accurately it can control the variator.
I'd think the contactors would be kinda difficult to switch accurately for short durations.
Mark, put some flyback diodes in the contactor dc coil circuit, i was thinking this might be flyback voltage
- Thank you received: 4153
3 years 2 months ago - 3 years 2 months ago #277664
Thanks, me too.
I just realized it needs an enable pin becasue from the original video, it is not allowed to move without the spindle turning. Something like:
Replied by rodw on topic Schaublin 125-CNC retrofit.
Thanks, me too.
pin in bit enable = 0 "set true when spindle is running with spindle.0.on";
if (!enable) //insert before switch statement
return;
Last edit: 3 years 2 months ago by rodw.
- spumco
- Thank you received: 905
3 years 2 months ago #277695
by spumco
Replied by spumco on topic Schaublin 125-CNC retrofit.
Would flyback voltage still spike and cause issues if the contactors are manually activated (i.e. screwdriver)? I'm genuinely curious.Mark, put some flyback diodes in the contactor dc coil circuit, i was thinking this might be flyback voltage
- Thank you received: 7491
3 years 2 months ago #277714
So am i.
Replied by tommylight on topic Schaublin 125-CNC retrofit.
So am i.
- scotth
- Thank you received: 62
3 years 2 months ago #277727
by scotth
Replied by scotth on topic Schaublin 125-CNC retrofit.
No eBay APP ID and/or Cert ID defined in Kunena configurationSomething like this should solve noise problems.
- Thank you received: 2177
3 years 2 months ago #277728
Replied by Aciera on topic Schaublin 125-CNC retrofit.
Given that there is no energy stored in the inductor (ie no collapsing magnetic field) I don't see where that voltage would come from.Would flyback voltage still spike and cause issues if the contactors are manually activated (i.e. screwdriver)? I'm genuinely curious.
Moderators: piasdom
Time to create page: 2.876 seconds
