Schaublin 125-CNC retrofit.
3 years 2 months ago #277737 by spumco
Replied by spumco on topic Schaublin 125-CNC retrofit.
Given that there is no energy stored in the inductor (ie no collapsing magnetic field) I don't see where that voltage would come from.
Me either, but I don't know everything about magic smoke.  Like maybe there's some sort of induced field in the coil when the main contacts make/break - and I've never learned about this situation but it's obvious to everyone else.
Once the magic smoke discussion moves past my internal understanding of "electricity is like water through a hose, only not" I have to start asking questions.
3 years 2 months ago - 3 years 2 months ago #277762 by smc.collins
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
a 20ohm fuel injector charged with 12v dc, can emit s much as 140v on shutoff depending on operating FZ and duty cycle.
a typical 24vdc contactor coil has a impedance of around 30-50 ohm. The flyback voltage could easily reach 140-200v on coil off especially if the contacts bounce as the field collapses. It's worth a look. ALOT of DC coils have built in diodes to prevent this, but maybe this unit does not.
Last edit: 3 years 2 months ago by smc.collins.
3 years 2 months ago #277767 by tommylight
Replied by tommylight on topic Schaublin 125-CNC retrofit.
@SMC
seems you have not seen his video on youtube, he pushes the relays by hand/screwdriver and still gets the error, so no relays in use.
3 years 2 months ago #277822 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
So this is how far I got so far...
Cheers,
Mark
The following user(s) said Thank You: tommylight, spumco
3 years 2 months ago #277825 by tommylight
No doughnuts! :)
3 years 2 months ago #277827 by Aciera
Replied by Aciera on topic Schaublin 125-CNC retrofit.
Ahhh, don't you just LOVE software solutions?
Nothing like 'fixing' a difficult hardware problem with your mouse and keyboard.
Moderators: piasdom
Time to create page: 0.348 seconds
