Huyndai hit 15s retrofit
- Mr.
01 Dec 2022 12:25 #258243
by Mr.
Replied by Mr. on topic Huyndai hit 15s retrofit
The pc im using used to be a mining rig so theres no issues with pci stuff, do we know if theres existing firmware for that setup?
About how much computing power does the pc need to have to run linuxcnc, ive only experanced mach3 and that didnt take any lol
- Thank you received: 4659
01 Dec 2022 16:19 #258265
I don't know, but I would imagine that the 5u24 is the most likely current board to drive a 7i36 so it there isn't then Mesa would probably make one if asked.
Replied by andypugh on topic Huyndai hit 15s retrofit
LinuxCNC needs very little CPU, it can run on Pis and Beaglebones, for example.About how much computing power does the pc need to have to run linuxcnc, ive only experanced mach3 and that didnt take any lol
The following user(s) said Thank You: Mr.
- Mr.
01 Dec 2022 20:16 #258285
by Mr.
Ok so i bought the 5i24+7i36+ribbon cable. Is there a tutorial to setup a pci type setup?
01 Dec 2022 20:51 #258289
They are slightly easier than the ethernet cards. Basically plug them in and flash the firmware (if it isn't already supplied with the right one)
As a first check, plug it in and run the following at the command line
That should load the drivers (and print out some useful information, in general)
Then:Will give a good idea what HAL pins (and hence functions) are in the firmware.
If you actually want to (manualy) switch the states of pins etc then there is a bit more to do (load a realtime thread, add the read/write functions to that). But you probably want to try the setup wizards and build a config at that point.
Having a quick fiddle, it doesn't look like pncconf knows abiout the 5i24 _or_ the 7i36 so there will be some manual tweaking (probably pretend you have a 7i53 and then edit the CARD string in the INI to match.
We will be able to help once you have the outline of a somewhat-close config set up.
halrun
loadrt hostmot2
loadrt hm2_pciThat should load the drivers (and print out some useful information, in general)
Then:
show pinIf you actually want to (manualy) switch the states of pins etc then there is a bit more to do (load a realtime thread, add the read/write functions to that). But you probably want to try the setup wizards and build a config at that point.
- Mr.
01 Dec 2022 22:41 #258294
by Mr.
Sounds good, i have some other stuff to do while i wait
Thanks again
Thanks again
- Mr.
03 Dec 2022 14:31 #258452
by Mr.
I was working thru the software (pncconf) today until i hit a wall at the card options, kinda lost honestly. Cards should be here soon enough but i figured i could get ahead a lil while my kids were sleeping. If the xorrect card options arnt there how do i move fwd?
Thanks for puttin up with me guys
- Online
- Thank you received: 7505
03 Dec 2022 15:28 #258455
Replied by tommylight on topic Huyndai hit 15s retrofit
On the first page of PncConf, click on "use name substitution for mesa cards" or similar.
Later chose a card of the same communication type, and something near what you ordered, example for 7i97, choose 7i92 and 7i77 .
That way you only need to change the card model in the ini file. And maybe some IO names.
- Mr.
05 Dec 2022 22:44 #258663
by Mr.
Got my cards today, not enough time to hook everything up ill do it sometime this week. Prob going to be alot of questions rolling out lol
- Mr.
06 Dec 2022 20:26 #258783
by Mr.
Well fellas made my first mistake lol, i assumed the 5i24 has a pcie i wasnt paying attn lol.
I
Options are to get a adaptor(not sure if this will cause problems)
Use another computer i have one with both pci and pcie but its slower(may not be a problem)
Return and get a pcie card
What you guys think
I
What you guys think
- Mr.
06 Dec 2022 21:26 #258784
by Mr.
Im leaning to the other computer, has p4 and was win xp ill boot it up and see. Ive already stripped it of the un nessery things
Moderators: piasdom
Time to create page: 0.135 seconds
