7i73 LCD shows rubisch
8 years 8 months ago #105609 by Mike_Eitel
Replied by Mike_Eitel on topic 7i73 LCD shows rubisch
HI My wife will kill me ;-)
could not resist and honor your effort... THX
I have 7i76e so had to modify your code to:
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config="sserial_port_0=21xxxx"
loadrt lcd fmt_strings="LinuxCNC - Tool %2i\n%b* X Pos = %11.4f%b* Y Pos = %11.4f%b* Z Pos = %10.3f|Long Number\n%015.2f\n"
loadrt threads
loadrt siggen
addf hm2_7i76e.0.read thread1
addf hm2_7i76e.0.write thread1
addf lcd thread1
addf siggen.0.update thread1
net chars lcd.00.out hm2_7i76e.0.7i73.0.1.display
start
setp lcd.00.contrast 0.7
net stuff lcd.00.page.00.arg.02 siggen.0.sine
net stuff1 lcd.00.page.00.arg.04 siggen.0.cosine
net stuff2 lcd.00.page.00.arg.06 siggen.0.triangle
setp lcd.00.page.00.arg.03 1
setp siggen.0.amplitude 1000
setp siggen.0.frequency 0.000005
Result is the same
Can see your text on the screen, but it is overwritten very fast, much more then the guessed 10 times per second
on various positions. The basic image is more or less "reconstructed" on the same place.
Mike
P.S.
I have to move in my bed now, when I intend to survive...
Big THX
Mike
8 years 8 months ago #105610 by andypugh
Replied by andypugh on topic 7i73 LCD shows rubisch
Using your example "ABC" string I get random letters all over the screen. But I get exactly the same thing if I pull 2.7 and recompile.
"ABC\n" works better, on both versions.
I think that there is definitely some room for improvement in the lcd component. But I am not seeing any difference at all between 2.7 and 2.8 versions of LinuxCNC on identical hardware.
8 years 8 months ago - 8 years 8 months ago #105612 by Grotius
Replied by Grotius on topic 7i73 LCD shows rubisch
@Mr.kuzminsky
The 2018 January 14 update went from 1:2.8.0~pre1.3405.ge10c52ea6 to 1:2.8.0~pre1.3520.g0a096c965, which is a pretty large jump that includes the commit Rene pointed out. So that's valuable debugging, thanks.
How do you solve this? is this pure looking to the code difference on git?
I like to look at difference also. Sometimes it's boring, but if it work's after compiling it can be great !
I like to learn more about linux.
Last edit: 8 years 8 months ago by Grotius.
8 years 8 months ago #105613 by andypugh
Well, to solve it first I need to find a way to detect the problem, then try to work out what changed in the code to cause it.
So far I am failing to detect the problem. So have no way to test possible fixes.
8 years 8 months ago #105615 by Grotius
@Andy,
I will try to look in the code difference on git between :
And then look carefully for changes in touchscreen. It can be a one letter mistake.
8 years 8 months ago #105619 by Mike_Eitel
I was never good in programming c, but i would look for a slightly changed size in an array, or a loop counter that does not fit anymore. I'm only guessing that the "real" positioning commands come from the 7i73 firmware.
Mike
Moderators: PCW, jmelson
Time to create page: 1.559 seconds
