7i73 LCD shows rubisch
8 years 8 months ago #105661 by Mike_Eitel
Replied by Mike_Eitel on topic 7i73 LCD shows rubisch
I use your test.hal.
When i quit that the red led (communication watchdog) of the 7i73 goes on.
I guess that the 7i76e stops in that very moment with the sserial transfers
8 years 8 months ago #105662 by andypugh
Replied by andypugh on topic 7i73 LCD shows rubisch
Ah, yes.
The LCD has it's own logic and just shows what it showed last if no more data is shown.
Can you definitely confirm that your LCD used to work perfectly? And can you remember when and with what version of LinuxCNC?
8 years 8 months ago #105664 by Mike_Eitel
Yes it worked like a charm! And more than only this one as i tested severals until i decided that big size. It was definitely always 2.8. never went 2.7.
For the version: very difficult. I had big problems to setup the system as it is today. Stretch is not easy for me and i started sever times with a wiped disk. I was around Christmas. But from with master version i do not know. It was surely based on the last iso. But sorry, cant even remember if i did an update in between.
8 years 8 months ago #105667 by andypugh
Mike_Eitel wrote: Yes it worked like a charm! .
What format string were you using? Maybe I can try that.
8 years 8 months ago - 8 years 8 months ago #105669 by Mike_Eitel
I do not understand. Do you mean string content? Does not matter. Every variation i tried has the same scrambling.
But actually i use the file exactly as posted yesterday in this thread.
I have 7i76e so had to modify your code to:
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config="sserial_port_0=21xxxx"
loadrt lcd fmt_strings="LinuxCNC - Tool %2i\n%b* X Pos = %11.4f%b* Y Pos = %11.4f%b* Z Pos = %10.3f|Long Number\n%015.2f\n"
loadrt threads
loadrt siggen
addf hm2_7i76e.0.read thread1
addf hm2_7i76e.0.write thread1
addf lcd thread1
addf siggen.0.update thread1
net chars lcd.00.out hm2_7i76e.0.7i73.0.1.display
start
setp lcd.00.contrast 0.7
net stuff lcd.00.page.00.arg.02 siggen.0.sine
net stuff1 lcd.00.page.00.arg.04 siggen.0.cosine
net stuff2 lcd.00.page.00.arg.06 siggen.0.triangle
setp lcd.00.page.00.arg.03 1
setp siggen.0.amplitude 1000
setp siggen.0.frequency 0.000005
Last edit: 8 years 8 months ago by Mike_Eitel.
8 years 8 months ago #105670 by andypugh
I was asking if you could send me the string that used to work perfectly and now doesn't.
Moderators: PCW, jmelson
Time to create page: 0.472 seconds
