Flash a XC6SLX9 dev board as a 7i90HD
7 years 6 months ago #131866 by PCW
Thats what you will get if you did not add your new card file to the sources list
7 years 6 months ago #131876 by gtt38
PCW wrote: Thats what you will get if you did not add your new card file to the sources list
In TopGCSPIHostMot2.vhd at the beginning ? Or in ISE tick boxes ?
7 years 6 months ago #131883 by PCW
The proper card type (you should really use your own name here) and pinout file must be included in the top level file
In addition, any source file used must be added to the project
(right click in file window and add if they are not listed)
7 years 6 months ago #131897 by dm17ry
PCW, a bit off topic.
but i was wondering... there's no PCI setup/hold timing constraints in the 5i25.ucf or elsewhere. how do you get away without them?
7 years 6 months ago - 7 years 6 months ago #131904 by PCW
They should be there, my oversight, though its not really possible to violate the
PCI specs rather generous 7 ns setup, 0 ns hold and 11 ns output offset specs at 33 MHz with one wait state.
Also the Async TRDY, DEVSEL and STOP signals should have pad-pad times
(more likely to be an issue at 66MHz)
I will look into adding these
Last edit: 7 years 6 months ago by PCW.
7 years 6 months ago - 7 years 6 months ago #131910 by dm17ry
thank you for clarification! have to study your PCI implementation... my PCI core implementation attempt effortlessly miss that generous 11ns output offset budget by 3ns on AD pins. among other less severe violations :)
Last edit: 7 years 6 months ago by dm17ry.
Moderators: PCW, jmelson
Time to create page: 0.356 seconds
