- Thank you received: 4
PCW wrote: You cannot change the EEPROM pin assignment if you expect the FPGA to load its configuration on startup (the configuration SPI pins are always on the same FPGA pins)
PCW wrote: You will also need a clock, the 7I90 assumes 50 MHz
