ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- juergenmoser
- Thank you received: 10
04 Jan 2023 14:52 #260930
by juergenmoser
Replied by juergenmoser on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Thank you very much! That would helps me a lot! When you have time it would be very nice when you can write the hal and ini file. I only need 3 Axes (X,Y,Z) 1 Input for home and 2 outputs for mist and flood and 1 pwm for spindle speed. I will also look at the example of the HAL file, so i can learn a little bit and try it out!
- juergenmoser
04 Jan 2023 18:13 #260942
by juergenmoser
Sorry TOLP to disturb again. Ive Tried installing litexcnc and get this error:
Collecting litexcnc
Could not install packages due to an EnvironmentError: 404 Client Error: Not Found for url: pypi.org/simple/litexcnc/
Is there an solution?
Collecting litexcnc
- TOLP2
- Thank you received: 178
04 Jan 2023 18:35 - 04 Jan 2023 18:37 #260945
by TOLP2
I think in my previous post I forgot the /simple/ part in the command. Will verify and change it there as well. Without this addition, Thanks for trying!
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
This is because there is no 'official' release to pypi.org yet. To install the package you should use:Sorry TOLP to disturb again. Ive Tried installing litexcnc and get this error:
Collecting litexcnc
pip install --extra-index-url https://test.pypi.org/simple/ litexcnc[cli]I think in my previous post I forgot the /simple/ part in the command. Will verify and change it there as well. Without this addition, Thanks for trying!
Last edit: 04 Jan 2023 18:37 by TOLP2. Reason: Add missing tag [cli]
- TOLP2
04 Jan 2023 18:53 #260948
by TOLP2
For your use case, you can use the pre-made configurations on this
documentation
page. You should download the documentation for the version of the board you have. I would recommend the use of the 'named' version of the configuration over the 'indexed' one. Why? With the 'named' version all pin numbers will show up in the HAL with their name, i.e. J1:1 (which is thus pin 1 on connector 1).
For your HAL, I think the code below is a nice starting point:
The above HAL-file needs a speciel section in the INI-file:
A good tactic for getting this up and running is to use the standard step config to generate the structure and the basis for your HAL file. Then you replace the stepgen with the part above and change the required settings.
loadrt [KINS]KINEMATICS
loadrt litexcnc
loadrt litexcnc_eth config_file="[LITEXCNC]CONFIG_FILE"
loadrt pos2vel number=3
# Add the functions to the thread
addf [LITEXCNC](NAME).read servo-thread
addf pos2vel.convert servo-thread
addf [LITEXCNC](NAME).write servo-thread
STEPGEN
# - timings (prevent re-calculation)
net pos2vel.period-s <= [LITEXCNC](NAME).stepgen.period-s
net pos2vel.period-s-recip <= [LITEXCNC](NAME).stepgen.period-s-recip
STEPGEN - X-AXIS
# POS2VEL
# - position control
net xpos-fb <= [LITEXCNC](NAME).stepgen.00.position_prediction
net xpos-fb => joint.0.motor-pos-fb
net xpos-fb => pos2vel.0.position-feedback
net xvel-fb pos2vel.0.velocity-feedback <= [LITEXCNC](NAME).stepgen.00.velocity-prediction
net xpos-cmd pos2vel.0.position-cmd <= joint.0.motor-pos-cmd
# - settings
setp pos2vel.0.max-acceleration [JOINT_0]STEPGEN_MAXACCEL
# setp pos2vel.0.debug 1
# STEPGEN
# - Setup of timings
setp [LITEXCNC](NAME).stepgen.00.position-scale [JOINT_0]SCALE
setp [LITEXCNC](NAME).stepgen.00.steplen 5000
setp [LITEXCNC](NAME).stepgen.00.stepspace 5000
setp [LITEXCNC](NAME).stepgen.00.dir-hold-time 10000
setp [LITEXCNC](NAME).stepgen.00.dir-setup-time 10000
setp [LITEXCNC](NAME).stepgen.00.max-velocity [JOINT_0]MAX_VELOCITY
setp [LITEXCNC](NAME).stepgen.00.max-acceleration [JOINT_0]STEPGEN_MAXACCEL
# setp [LITEXCNC](NAME).stepgen.00.debug 1
# - Connect velocity command
net pos2vel.0.velocity-cmd => [LITEXCNC](NAME).stepgen.00.velocity-cmd
# - Set the acceleration to be used (NOTE: pos2vel has fixed acceleration)
setp [LITEXCNC](NAME).stepgen.00.acceleration-cmd [JOINT_0]STEPGEN_MAXACCEL
# - enable the drive
net xenable joint.0.amp-enable-out => [LITEXCNC](NAME).stepgen.00.enable
STEPGEN - Y-AXIS
# POS2VEL
net ypos-fb <= [LITEXCNC](NAME).stepgen.01.position_prediction
net ypos-fb => joint.1.motor-pos-fb
net ypos-fb => pos2vel.1.position-feedback
net yvel-fb pos2vel.1.velocity-feedback <= [LITEXCNC](NAME).stepgen.01.velocity-prediction
net ypos-cmd pos2vel.1.position-cmd <= joint.1.motor-pos-cmd
# - settings
setp pos2vel.1.max-acceleration [JOINT_1]STEPGEN_MAXACCEL
# setp pos2vel.1.debug 1
# STEPGEN
setp [LITEXCNC](NAME).stepgen.01.position-scale [JOINT_1]SCALE
setp [LITEXCNC](NAME).stepgen.01.steplen 5000
setp [LITEXCNC](NAME).stepgen.01.stepspace 5000
setp [LITEXCNC](NAME).stepgen.01.dir-hold-time 10000
setp [LITEXCNC](NAME).stepgen.01.dir-setup-time 10000
setp [LITEXCNC](NAME).stepgen.01.max-velocity [JOINT_1]MAX_VELOCITY
setp [LITEXCNC](NAME).stepgen.01.max-acceleration [JOINT_1]STEPGEN_MAXACCEL
# setp [LITEXCNC](NAME).stepgen.01.debug 1
net pos2vel.1.velocity-cmd => [LITEXCNC](NAME).stepgen.01.velocity-cmd
setp [LITEXCNC](NAME).stepgen.01.acceleration-cmd [JOINT_1]STEPGEN_MAXACCEL
net xenable joint.1.amp-enable-out => [LITEXCNC](NAME).stepgen.01.enable
STEPGEN - Z-AXIS
# POS2VEL
net zpos-fb <= [LITEXCNC](NAME).stepgen.02.position_prediction
net zpos-fb => joint.2.motor-pos-fb
net zpos-fb => pos2vel.2.position-feedback
net zvel-fb pos2vel.2.velocity-feedback <= [LITEXCNC](NAME).stepgen.02.velocity-prediction
net zpos-cmd pos2vel.2.position-cmd <= joint.2.motor-pos-cmd
# - settings
setp pos2vel.2.max-acceleration [JOINT_2]STEPGEN_MAXACCEL
# setp pos2vel.2.debug 1
# STEPGEN
setp [LITEXCNC](NAME).stepgen.02.position-scale [JOINT_1]SCALE
setp [LITEXCNC](NAME).stepgen.02.steplen 5000
setp [LITEXCNC](NAME).stepgen.02.stepspace 5000
setp [LITEXCNC](NAME).stepgen.02.dir-hold-time 10000
setp [LITEXCNC](NAME).stepgen.02.dir-setup-time 10000
setp [LITEXCNC](NAME).stepgen.02.max-velocity [JOINT_2]MAX_VELOCITY
setp [LITEXCNC](NAME).stepgen.02.max-acceleration [JOINT_2]STEPGEN_MAXACCEL
# setp [LITEXCNC](NAME).stepgen.02.debug 1
net pos2vel.1.velocity-cmd => [LITEXCNC](NAME).stepgen.02.velocity-cmd
setp [LITEXCNC](NAME).stepgen.02.acceleration-cmd [JOINT_2]STEPGEN_MAXACCEL
net xenable joint.2.amp-enable-out => [LITEXCNC](NAME).stepgen.02.enable
[LITEXCNC]
CONFIG_FILE=<path to your config file>
NAME=<name of the card from the config file>
- juergenmoser
04 Jan 2023 20:03 #260956
by juergenmoser
I´m Sorry but this link also not working. I have put now to the test.pypi.org to firefox and I searching for litexcnc - tadaa - there it is - don`t know why.
So I downloaded the Source Distribution
litexcnc-0.9.0a3.tar.gz
- TOLP2
04 Jan 2023 20:18 - 04 Jan 2023 20:26 #260958
by TOLP2
Strange, can you please share your input and output from your command line, i.e.:
There are also some other possibilities:
$ pip install --extra-index-url https://test.pypi.org/simple/ litexcnc[cli]
Defaulting to user installation because normal site-packages is not writeable Looking in indexes: https://pypi.org/simple, https://test.pypi.org/simple/ Collecting litexcnc[cli]
Downloading https://test-files.pythonhosted.org/packages/45/35/86d98714ca9f6eb2338866578aaf616a5a05118ee6c346d6bb77b4d0a406/litexcnc-0.9.0a3-py3-none-any.whl
(146 kB) ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 146.3/146.3 kB 753.4 kB/s eta 0:00:00There are also some other possibilities:
- you need Python 3.8 or higher. So if you have 3.7 installed, pip cannot find this version;
- if you have Python 3.8, your might use pip3 depending on your system. The standard pip might default to Python 2.x version.
- last resort: update pip (pip install -U pip)
Last edit: 04 Jan 2023 20:26 by TOLP2.
- juergenmoser
04 Jan 2023 20:49 #260961
by juergenmoser
So I think thats my problem - i have Python 3.7 installed.I Will update pip. How can I Upload to python 3.8? also when i try the command without pip3 and only pip the say I have only Python 2.7 Installed..
- TOLP2
04 Jan 2023 20:59 #260963
by TOLP2
Checking at this moment whether it installs on Python 3.7. If it works, I'll directly release a new version.
The following user(s) said Thank You: juergenmoser
- juergenmoser
04 Jan 2023 21:17 #260965
by juergenmoser
Hmm i dont know whats the problem...
cnc@debian:~$ pip3 install https://test-files.pythonhosted.org/packages/05/6c/6493aa81992f8fc84eeb2934bdc568b30791c529b40915bd272baa976455/litexcnc-0.9.0a3.tar.gz
Collecting https://test-files.pythonhosted.org/packages/05/6c/6493aa81992f8fc84eeb2934bdc568b30791c529b40915bd272baa976455/litexcnc-0.9.0a3.tar.gz
Using cached https://test-files.pythonhosted.org/packages/05/6c/6493aa81992f8fc84eeb2934bdc568b30791c529b40915bd272baa976455/litexcnc-0.9.0a3.tar.gz
Installing build dependencies ... done
litexcnc requires Python '>=3.8,<4.0' but the running Python is 3.7.3
cnc@debian:~$ python --version
Python 2.7.16
cnc@debian:~$ python3 --version
Python 3.8.16
cnc@debian:~$
- TOLP2
04 Jan 2023 21:29 #260968
by TOLP2
Seems like you have multiple python installations on your system. I just released alpha-4, which does support Python 3.7, so you should be able installing it with the first command.
If the python 3.7 installation is on path (which is assume to be, as pip3 is on path), the scripts like install_driver should work and you won;t have to bother with the Python version hell.
Time to create page: 4.582 seconds
