ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
3 years 9 months ago #261129 by juergenmoser
@TOLP i tried to install litexcnc yesterday with the original ISO LinuxcncBuster 2.8.0 and i can‘t get it to work. So I tried the excellent manual from tommylight (I think)to install mint21 (for me no worries because i run the tests on a virtual machine)  with linuxcnc2.9 - and it all works like a charm! The only thing what you have maybe to install is „pip“ and maybe „git“ after that you can install litexcnc very easily! Thanks again for the help!
The following user(s) said Thank You: TOLP2
3 years 9 months ago #261167 by DePrutser
I'm trying to follow the steps in README.md from github.com/Peter-van-Tol/LiteX-CNC
I get this error on the first step on my arch linux system:
[cedric@cedric ~]$ pip install litexcnc
Defaulting to user installation because normal site-packages is not writeable
ERROR: Could not find a version that satisfies the requirement litexcnc (from versions: none)
ERROR: No matching distribution found for litexcnc
[cedric@cedric ~]$ uname -a
Linux cedric 6.0.11-arch1-1 #1 SMP PREEMPT_DYNAMIC Fri, 02 Dec 2022 17:25:31 +0000 x86_64 GNU/Linux
Next I try the same command on my linuxcnc installation:
$ sudo apt-get install python3-pip
$ pip3 install litexcnc
Collecting litexcnc
Could not install packages due to an EnvironmentError: 404 Client Error: Not Found for url: pypi.org/simple/litexcnc/
$ sudo apt-get install python-pip
Collecting litexcnc
$ uname -a
Linux virt-cnc 4.19.0-21-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.249-2 (2022-06-30) x86_64 GNU/Linux
$ cat /etc/issue
Debian GNU/Linux 10 \n \l
What am I doing wrong?
3 years 9 months ago #261169 by TOLP2
@DePrutser: at this moment litexcncis not yet available on the official PyPi.org. The pre-release is available at test.pypi.org. To install it, please use this command:
pip install --extra-index-url https://test.pypi.org/simple/ litexcnc[cli]
I will update the README.md to show the correct command. For documentation, please refer  ReadTheDocs .
3 years 9 months ago - 3 years 9 months ago #261186 by juergenmoser
@TOLP - Hello again - So the Litex drivers are already installed - also a board 5a75b v8.0 is flashed - (and ping went good) when I try halrun -> loadrt litexcnc i get this error
cnc@cnc-LIFEBOOK-E744:~$ halrun halcmd: loadrt litexcnc Note: Using POSIX realtime litexcnc: dlopen: /usr/lib/linuxcnc/modules/litexcnc.so: undefined symbol: json_object_array_length <stdin>:1: waitpid failed /usr/bin/rtapi_app litexcnc <stdin>:1: /usr/bin/rtapi_app exited without becoming ready <stdin>:1: insmod for litexcnc failed, returned -1 halcmd: exit Note: Using POSIX realtime So i think when i reinstall the litex_driver i can see that the position250 is the board name? is there a maximum lengh maybe? (I Only Uses 6 letters....)
  250 |         rtapi_snprintf(fpga->name, sizeof(fpga->name), json_object_get_string(board_name));       |         ^~~~~~~~~~~~~~
My System: [code]Linux cnc-LIFEBOOK-E744 6.0.0-6-rt-amd64 #1 SMP PREEMPT_RT Debian 6.0.12-1 (2022-12-09) x86_64 x86_64 x86_64 GNU/Linux LinuxCNC Version 2.9
[/code]
Last edit: 3 years 9 months ago by juergenmoser.
3 years 9 months ago #261196 by TOLP2
I have to check, did you use:
litexcnc install_driver
or (in case of permission denied error)
sudo litexcnc install_driver
If this is the case, I have to dive into the code. At this moment I cannot verify this, as I'm rebuilding my system, will be Monday to have this done.
3 years 9 months ago - 3 years 9 months ago #261199 by juergenmoser
I‘ve done it with sudo (so that everything goes to $PATH) No worries - I have time!
Moderators: PCW, jmelson
Time to create page: 0.415 seconds
