ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
3 years 9 months ago #260992 by wuyatom
The command cannot be recognized. Is there a problem with my python 3.8 environment
3 years 9 months ago #260998 by juergenmoser
Hi Muvideo!
Thank you for your excellent discription and explanations!  Now I am understanding it a little bit more. Also now I Understand why my Steppers are not working - I count at the Pin Header the Wrong Pins  So I typed in the HUB75 Pinout at google and now I see what I have doing wrong!
Thank you all for your helping. @ TOLP I will also try at night your new file from pypi.org and will test it.
3 years 9 months ago - 3 years 9 months ago #261001 by TOLP2
@wuyatom: Unverified, but I think you can also try to call:
python -m litexcnc install_driver
I'm typing on a smartphone, so cannot verify at this moment.
Edit:
Just verified that indeed you can use the command above. Make sure that when you call python it starts the correct version where litexcnc is installed. In some cases you must use python3 or python38.
Last edit: 3 years 9 months ago by TOLP2. Reason: Verified solution
3 years 9 months ago - 3 years 9 months ago #261010 by deroj
Hi.
I am following this with big interesst.
But one, maybe stupid, question.
How do i get the bit file into the fpga?
I tried a raspberry pi 4 with openocd and bcm2835gpio. didn
t work.
altera usb-blaster from amazon and openfpgaloader, didn`t work...
do you have a setup for me that work?
thank you
OKay...my fault. forgot to install the FTDI driver with openocd...no it works.
But when I try to install the driver it gives me permission errors.
litexcnc install_driver :
Linking litexcnc.so cp litexcnc.so /usr/lib/linuxcnc/modules/ cp: reguläre Datei '/usr/lib/linuxcnc/modules/litexcnc.so' kann nicht angelegt werden: Keine Berechtigung make: *** [/usr/share/linuxcnc/Makefile.modinc:105: install] Fehler 1
Last edit: 3 years 9 months ago by deroj.
3 years 9 months ago #261024 by deroj
I gave it another try.
I tried
"sudo python3 halcompile.py --install litexcnc.c litexcnc_eth.c litexcnc_debug.c stepgen/pos2vel.c"
it run and copied both files.
then i run halrun to test it.
oj@oj-turner:~/LiteX-CNC$ halrun halcmd: loadrt litexcnc Note: Using POSIX realtime litexcnc: dlopen: /usr/lib/linuxcnc/modules/litexcnc.so: undefined symbol: json_object_array_length <stdin>:1: waitpid failed /usr/bin/rtapi_app litexcnc <stdin>:1: /usr/bin/rtapi_app exited without becoming ready <stdin>:1: insmod for litexcnc failed, returned -1
3 years 9 months ago - 3 years 9 months ago #261026 by TOLP2
Can you try to use:
sudo litexcnc install_driver
If you have installed litexcnc in the user directory (either with the --user tag or it defaulted to it and a warning was given), you might have to reinstall the package. But give it a try first, if it says that litexcnc is not installed, then you need to reinstall. Reinstallation is easy with these commands:
pip uninstall litexcnc sudo pip install --extra-index-url https://test.pypi.org/simple/ litexcnc
Edit:
I just missed your message and now see that you are compiling by hand. That won't work, as it is required to link the library with lib_json. Please use the commands above, as this will download the required libraries and link them correctly.
Moderators: PCW, jmelson
Time to create page: 1.427 seconds
