- Thank you received: 30
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- muvideo
The homing configuration should not block the motor from moving, maybe there Is something else not working in your case. You say that the board Is enabled, have you double checked the board pinout?Hi muvideo,
okay thanks - i connected a stepper and i was wondering why it‘s not moving. I tried all axes/joints. (Card enabled and ready)So i will try to modify the home latching etc. all to zero.
Thanks all for the help!
Verify that you are connecting the stepper driver to the right pins. Do you have means to check if a pin Is driven? (Dvm or scope)
- juergenmoser
- Thank you received: 10
- vre
- Thank you received: 17
I have found 74LVC245A .. which old buffers to remove ? are all the same ?
U15/U12/U38/U20 are ok to replace ?
Exists some photo to show which buffer are connected to each idc16 connector ?
- TOLP2
- Thank you received: 178
I do not recommend to replace the buffers for the shared pins. Each IDC connector has their own buffer, so this would lead to have them all replaced.Transceivers U23,U24,U28 completely cover RGB pins on J1,J2,J3,J4Transceivers U25,U26,U27 completely cover RGB pins on J5,J6,J7,J8Transceivers U14,U16,U18 completely cover RGB pins on J9,J10,J11,J12Transceivers U9,U12,U15 completely cover RGB pins on J13,J14,J15,J16
- vre
Must replace U23,U24,U28 U25,U26,U27 U14,U16,U18 U9,U12,U15 ?
or can replace only U23,U24,U28 for convert J1,J2,J3,J4 to inputs ?
Hot air works for desoldering or it is more safe to cut legs of old buffers ?
- TOLP2
Pons 1, 2 3, 5, 6 and 7 are individual pins. Pin 4 and 16 are ground. The remainder of the pins are shared pins. Of these shared pins, pin 8 (E) is special, as in some displays this one is connected to ground.which pins are shared ?
It will suffice to replace only U23, U24 and U28 in this case. When using mij breakout boards I recommend to replace the buffers in groups of 3 to prevent 'wasted' pins.Must replace U23,U24,U28 U25,U26,U27 U14,U16,U18 U9,U12,U15 ?
I do have a hot air station. My experience with using this to desolder buffers is not good, pads are coming loose from the board. This might also be due to my lack of skill.Hot air works for desoldering or it is more safe to cut legs of old buffers ?
With cutting the legs I've never had any problem, so I deem this method safer.
