- Thank you received: 178
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- TOLP2
3 years 10 months ago #260264
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Merry Christmas to everybody. I would like to thank everybody for their support in making the firmware and driver last year.
Wish everybody good days and stay safe!
The following user(s) said Thank You: tommylight, Pro_El, muvideo
- TOLP2
3 years 10 months ago #260356
by TOLP2
Today I finally merged and deleted the branch 'envoders' in which I was developing the support for encoders. Tested the working for encoders successfully and put everything in main. Some nice facts / features on the encoders:
- In the JSON-config you can set minimum and maximum value for the encoders. This plays really nice for setting feed, rapid and spindle override. You can directly use the output of the encoder counts with gmoccapy or you can use the scaled value to simulate an potentiometer with this function
- In the JSON-config you can set the reset_value. This is the value to which the counts are set on the FPGA when either the FPGA is being reset (for example at start up of LinuxCNC) or when the index enable is set to TRUE and an index pulse happens.
- A breakout board for fast encoders is available. The speed aimed for is 1 MHz.
The following user(s) said Thank You: wzor
- TOLP2
3 years 10 months ago - 3 years 10 months ago #260394
by TOLP2
My 5a-75e is ff-up. Does any one in Europe, or even better in The Netherlands, have a spare card? It takes so long to get a new one otherwise.
Update:
Just ordered two more cards. Spend more then 8 hours trying to rewire the broken traces and fix the buffers. But I think some more of the board has been damaged, because I cannot get any response from the JTAG. Either something shortened out in the FPGA and had it fried, or something else is terrible wrong which I cannot solve.
The new boards will arrive on 15th of January (if everything goes well), then I'll be back in business.
Update:
Last edit: 3 years 10 months ago by TOLP2.
- juergenmoser
- Thank you received: 10
3 years 10 months ago #260540
by juergenmoser
Replied by juergenmoser on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Hello together, i am a beginner at this point. I have one Question - can i use this board (5a75b) also only for stepper motors without encoder feedback?
Kind regards
Kind regards
- romanetz
- Thank you received: 45
3 years 10 months ago #260543
by romanetz
Replied by romanetz on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Surely. Moreover, if you don't need even digital inputs you can run 5A-75B without any hardware modifications.
The following user(s) said Thank You: juergenmoser
- Thank you received: 7491
3 years 10 months ago #260556
Replied by tommylight on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Yes, with normal step/dir drives.
Time to create page: 0.215 seconds
