- Thank you received: 10
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- juergenmoser
3 years 9 months ago #260903
by juergenmoser
Replied by juergenmoser on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Hello Together again - I have found now a solution in my Joint Following Error on the Z Axis
At Fabios Github repo ( github.com/faeboli/Lcnc/blob/master/supp...cncMill/LcncMill.hal )
I have copied his configuration to test my steppers.
I found an Error in the LcncMill.hal File:# Joint 2 setup setp Lcnc.00.stepgen.00.scale [JOINT_2]SCALE setp Lcnc.00.stepgen.02.acc_lim [JOINT_2]STEPGEN_MAXACCEL # setp Lcnc.00.stepgen.00.enable true
so i have changed the stepgen.02.acc_lim to stepgen.00.acc_lim and now i have no more Joint Following Errors. Maybe if some tried also this configuration it helps a little bit
(Maybe also Fabio can change this error in the GitHub Repo)
Another Question: Are the Outputs from the stepgen Step/Dir +3V3? so can I connect it to a stepper driver (STEP/DIR)and only need a ground
Pin? or is this Inverted?
(Maybe also Fabio can change this error in the GitHub Repo)Another Question: Are the Outputs from the stepgen Step/Dir +3V3? so can I connect it to a stepper driver (STEP/DIR)and only need a ground
The following user(s) said Thank You: muvideo
- TOLP2
- Thank you received: 178
3 years 9 months ago #260904
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
The 5A-75E has 5 Volt outputs (therefore they have those buffers). Depending on your driver you can van connect these directly. I know Leadshine, Polulu, Lichuan can. Please refer to their documentation.
- juergenmoser
3 years 9 months ago #260906
by juergenmoser
Okay thank you for the quick reply - I have a 5a75b.
I was only a little bit confused because there are no step and dir pins connected by the joints in the hal file.
I know only a little bit about PID - So for my Understanding the PID gives the command to the FPGA and the FPGA produces the Step/Dir signals which goes to the Buffers- right?
- TOLP2
3 years 9 months ago #260917
by TOLP2
Not to make it more complex: your understanding is roughly correct.
If you don't like the PID and tuning of it, you might also want to try Litex-CNC and it's pos2vel component.
The following user(s) said Thank You: juergenmoser
- juergenmoser
3 years 9 months ago - 3 years 9 months ago #260920
by juergenmoser
Thanks for your information - Yeah I have no idea how to tune the PID for STEP/Dir or what exactly to do with it. Maybe i`ts better to try Litex-CNC - does anybody or maybe you have a instruction or maybe a hal and ini File for LitexCNC with a Stepgen?
Edit: I have read the readme of LitexCNC - so i have to build a new Firmware. (And can I take the same Firmware (LCNC from Fabio) from the FPGA or do I have to make a new Bitfile for Litex-CNC as well?)
Last edit: 3 years 9 months ago by juergenmoser.
- TOLP2
3 years 9 months ago #260929
by TOLP2
The functionality of both is the same. However, the information transferred is not. You have to rebuilt the firmware.
For Litex-CNC the configuration is done using JSON-files. Some examples of these files are given on the documentation page. You can download them, verify the settings and built them. If you want, I can make a specific config for you as well this evening. Need to know the number of gpio in / out, stepgen, pwm and encoders.
On the documentation there are also examples of the HAL files available per module.
I tried to make Litex-CNC as user friendly as possible. It is installable from PyPi.org:
To install the driver, litex and toolchain
When you have your configuration, you can build it using the command:
After that you can upload the generated bit-file to your board and start connecting your HAL.
Per module there is an example on how to design your HAL file. An example for stepgen is given here . I only noticed just now that the documentation for encoders is missing. Will add that soon.
pip install --extra-index-url https://test.pypi.org/simple/ litexcnc[cli]
litexcnc install_driver
litexcnc install_litex
litexcnc install_toolchain
litexcnc build_firmware "<path-to-your-configuration>" --build
Time to create page: 1.034 seconds
