ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
3 years 7 months ago #267257 by Bari
The project is still at the mercy of hardware vendors that make these boards for signage.
3 years 7 months ago #267399 by romanetz
The board is almost totally reverse-engineered, but without such a bulk production one won't get this affordable price
3 years 7 months ago #267672 by deroj
I really like this project.
Today the second 5A-75B-V8.0 will arrive. Can“t wait to flash it with LiteX.
And when I get the workflow for the modules finally, things will become even more exciting
3 years 6 months ago #268348 by romanetz
@TOLP2 can you explain how to deal with stepgen constraints and how to set them properly? Imagine that one is implementing a machine with servo drives configured to 1000 steps/mm and maximum speed 1m/sec (60m/min) (this yields 1 MHz step clock). Let servo period will be 500 usec, jitter is 10 usec (10/500=2%) and expected joint following error 20 um at a maximum speed (possible position error caused by jitter at a maximum speed: 10us*1m/sec=+-10 um). Are these values achievable? How to set up pick up value properly?
3 years 6 months ago - 3 years 6 months ago #268393 by deroj
Maybe this answer which helped me, will help you....
forum.linuxcnc.org/27-driver-boards/4442...ard?start=490#263931
As mentioned in the documentation, the max step frequency will be 400kHz
Last edit: 3 years 6 months ago by deroj.
3 years 6 months ago #268606 by tuxcnc
There is already 54 pages...
Can anybody give brief info, is ColorCNC works, is ready for use in real machine, and how to install it?
Thanks in advance.
Moderators: PCW, jmelson
Time to create page: 0.145 seconds
