- Thank you received: 178
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- TOLP2
3 years 8 months ago #265431
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Could you please explain what you are trying to achieve. Without this, it is difficult to judge what the problem might be. Please:[code]
net x-index-enable => pid.x.index-enable <= joint.0.index-enable => [LITEXCNC](NAME).encoder.00.index_enable
net x-enable pid.x.enable <= joint.0.amp-enable-out => [LITEXCNC](NAME).stepgen.00.enable => [LITEXCNC](NAME).gpio.j11:1.out
net x-pos-cmd joint.0.motor-pos-cmd => pid.x.command
net x-vel-fb [LITEXCNC](NAME).encoder.00.velocity => pid.x.feedback-deriv
net axis.0.motor-pos-fb <= [LITEXCNC](NAME).encoder.00.position => pid.x.feedback
net x-output pid.x.output => [LITEXCNC](NAME).stepgen.00.velocity-cmd
[code]
Is there a problem with the syntax of my encoder connection? I don't know whether there is a problem with my hal or my hardware connection
- add your machine config, so we can try to replicate your error;
- give a description of what the machine should do;
- give a description of what the machine is actually doing.
- T = 0 cycle: LinuxCNC reads the FPGA and thus encoder position, which is the current position;
- T = 0.1 cycle: LinuxCNC processes the information and determines how fast the motor should move to get to the wanted position;
- T = 0.5 cycle: The data is then send to the FPGA, together with an apply time. From this timestamp the movement is started and this will be in the future;
- T = 0.5 cycle: The FPGA processes the data, but is not moving yet as it awaits the apply time.
- T = 0.9 cycle: The FPGA commands the steppers to move
- T = 1.0 cycle: .... the process starts again.
- have to close the loop in the FPGA;
- have to make a module which can predicted the position at the start of the next cycle.
- wuyatom
3 years 8 months ago #265472
by wuyatom
Replied by wuyatom on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
I think the input of 5A-75E is connected to the encoder output interface of the servo driver to achieve full closed-loop control
- deroj
- Thank you received: 21
3 years 8 months ago #265508
by deroj
Replied by deroj on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Sorry...This doesn´t work either.To run litexcnc in your poetry environment, please use:
sudo -E env PATH=$PATH poetry run litexcnc install_driver
oj@VMLinuxCNC:~$ sudo -E env PATH=$PATH poetry run litexcnc install_driver
[sudo] Passwort für oj:
/home/oj/src/litexcnc does not contain any element
- TOLP2
3 years 8 months ago #265519
by TOLP2
If you don't use your encoders, you can connect it like this (see also [url] litex-cnc.readthedocs.io/en/latest/modules/stepgen.html [/url]):
When you want to close-the-loop with using the encoders, you have to find your way to get the information to back to motmod.
There is one thing missing in your HAL-file: you have to connect the feedback of the position to the motmod. The pin joint.N.motor-pos-fb is currently not connected in your HAL. This will cause joint following errors, because the motmod won't see your axis responding to the input.I think the input of 5A-75E is connected to the encoder output interface of the servo driver to achieve full closed-loop control
net xpos-fb <= [LITEXCNC](NAME).stepgen.00.position_prediction
net xpos-fb => joint.0.motor-pos-fb
- TOLP2
3 years 8 months ago #265520
by TOLP2
Also...
I implemented the aforementioned improvements in Litex-CNC. When pulling the latest version from this GitHub branch you can now load extra modules and directly connect to the FPGA, for example with:
The above statement will load the extra module toolerator and will connect to a FPGA using:
This error is due to an error in your project. Can you share the location of you repository or a zip-file with your code, the I can correct the error for you.To run litexcnc in your poetry environment, please use:
Sorry...This doesn´t work either.Code:oj@VMLinuxCNC:~$ sudo -E env PATH=$PATH poetry run litexcnc install_driver [sudo] Passwort für oj: /home/oj/src/litexcnc does not contain any element
Also...
loadrt extra_modules="toolerator" connections="eth:10.0.0.10:1234"
- ethernet / etherbone protocol (this is the only supported protocol at this moment);
- the ip-address 10.0.0.10 (adjust this to the value in your config json);
- the port 1234 (when the port is 1234, this can be omitted, as 1234 is the default).
- deroj
3 years 8 months ago #265523
by deroj
Don't think it is an error in my project because I did not add one.
I am just not familiar with poetry and/or your workflow
Deleted litexcnc from the python site-package folder.
Reinstalled it with pip (0.9.0a5)
Did the poetry add git+http://......
Then sudo ... poetry run litexcnc....
Time to create page: 1.230 seconds
