- Thank you received: 45
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- romanetz
3 years 4 months ago #274558
by romanetz
The way of configuration has changed: in this branch, the configuration is prepared during gateware (==the firmware of FPGA) compilation and upon start the driver fetches it from the FPGA. Also, the current state of firmware expects another structure of configuration JSON file. I appreciate any help regarding this issue as the new way of configuration is not documented yet.
Replied by romanetz on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Work on the project is in progress in another branch, github.com/Peter-van-Tol/LiteX-CNC/tree/...tensions-to-litexcncHello all,
Can someone explain is 5A-75E board work now or still is work in progress as i presume
I wach this topic, but is quiet for some time..
I have two of this board so if someone need to test something i can do that..
github Peter-van-Tol is not updated from January, is it stoped development or is in other github project active??
github.com/Peter-van-Tol/LiteX-CNC/commits/main
The following user(s) said Thank You: Pro_El
- tuxcnc
- Thank you received: 56
3 years 3 months ago #274675
by tuxcnc
Replied by tuxcnc on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Can anyone force (11-add-external-extensions-to-litexcnc) an encoder to work ?
- deroj
- Thank you received: 21
3 years 3 months ago #274809
by deroj
Replied by deroj on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- tuxcnc
3 years 3 months ago #274830
by tuxcnc
I got some hal pins but values not change when encoder acts.
I need working hal configuration.
Yes.Have you tried this?
litex-cnc.readthedocs.io/en/11-add-exter...modules/encoder.html
- meister
- Thank you received: 502
3 years 3 months ago #274831
by meister
Replied by meister on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
some encoder needs pullup resistors
- tuxcnc
3 years 3 months ago - 3 years 3 months ago #274833
by tuxcnc
Most of encoders needs pullups.
These have built-in can burn 3.3 V inputs...
I always use pullups and Schottky diodes.
Last edit: 3 years 3 months ago by tuxcnc.
Time to create page: 1.434 seconds
