- Thank you received: 56
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- tuxcnc
This is what I need.3 Joints are already work and move
- juergenmoser
- Thank you received: 10
Google Drive with Bitfile and JSON:
drive.google.com/drive/folders/1y_3T1eHn...crYeb?usp=drive_link
I Also made a PCB Layout which hits perfectly on the 5A75B
You can Import the DXF as a Document (KiCAD, EAGLE, etc.) then you have the exact matching for positioning your headers.
Google Drive:
drive.google.com/file/d/1yBUNk07vlnOByhx.../view?usp=drive_link
- deroj
- Thank you received: 21
git checkout and pip3 install ./ gives error.
seems like it deletes the temp files too early....
It is the DEBIAN 10 LinuxCNC 2.8.4 ISOoj@debian:~/LiteX-CNC$ pip3 install ./
Processing /home/oj/LiteX-CNC
Installing build dependencies ... done
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
File "/usr/lib/python3.7/tokenize.py", line 447, in open
buffer = _builtin_open(filename, 'rb')
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/pip-req-build-ox305jnb/setup.py'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-req-build-ox305jnb/
FileNotFoundError: [Errno 2] No such file or directory: '/tmp/pip-req-build-i5bpps12/setup.py'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-req-build-i5bpps12/
- romanetz
- Thank you received: 45
- Pro_El
- Thank you received: 3
Can someone explain is 5A-75E board work now or still is work in progress as i presume
I wach this topic, but is quiet for some time..
I have two of this board so if someone need to test something i can do that..
github Peter-van-Tol is not updated from January, is it stoped development or is in other github project active??
github.com/Peter-van-Tol/LiteX-CNC/commits/main
- romanetz
