ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- RiJa
3 years 3 months ago #275256
by RiJa
Replied by RiJa on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
@deroj
Because I installed it with poetry i can only run the command poetry run litexcnc install_driver inside the folder with sudo
cnc@debian:~/Desktop/LiteX-CNC-11-add-external-extensions-to-litexcnc$ sudo -E env PATH=$PATH poetry run litexcnc install_driver
INFO: Retrieving default driver files to compile...
Copying file 'watchdog.c'
Copying file 'litexcnc.c'
Copying file 'wallclock.c'
Copying file 'litexcnc_eth.c'
Copying file 'etherbone.c'
Copying file 'litexcnc_gpio.c'
Copying file 'litexcnc_stepgen.c'
Copying file 'litexcnc_encoder.c'
Copying file 'litexcnc_pwm.c'
Copying file 'pos2vel.c'
Copying file 'watchdog.h'
Copying file 'wallclock.h'
Copying file 'litexcnc.h'
Copying file 'etherbone.h'
Copying file 'litexcnc_eth.h'
Copying file 'litexcnc_encoder.h'
Copying file 'litexcnc_pwm.h'
Copying file 'litexcnc_gpio.h'
Copying file 'litexcnc_stepgen.h'
Copying file 'pos2vel.h'
INFO: Compiling LitexCNC driver...
Compiling realtime litexcnc.c
litexcnc.c: In function ‘litexcnc_register’:
litexcnc.c:519:1: warning: label ‘fail0’ defined but not used [-Wunused-label]
519 | fail0:
Linking litexcnc.so
cp litexcnc.so /usr/lib/linuxcnc/modules/
Compiling realtime pos2vel.c
Linking pos2vel.so
cp pos2vel.so /usr/lib/linuxcnc/modules/
Compiling realtime litexcnc_eth.c
Linking litexcnc_eth.so
cp litexcnc_eth.so /usr/lib/linuxcnc/modules/
Compiling realtime litexcnc_gpio.c
Linking litexcnc_gpio.so
cp litexcnc_gpio.so /usr/lib/linuxcnc/modules/
Compiling realtime litexcnc_stepgen.c
Linking litexcnc_stepgen.so
cp litexcnc_stepgen.so /usr/lib/linuxcnc/modules/
Compiling realtime litexcnc_encoder.c
Linking litexcnc_encoder.so
cp litexcnc_encoder.so /usr/lib/linuxcnc/modules/
Compiling realtime litexcnc_pwm.c
Linking litexcnc_pwm.so
cp litexcnc_pwm.so /usr/lib/linuxcnc/modules/
INFO: LitexCNC driver installed
- deroj
- Thank you received: 21
3 years 3 months ago - 3 years 3 months ago #275257
by deroj
Replied by deroj on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
and the files are really in the /usr/lib/linuxcnc/modules/ folder?
how did you install LinuxCNC?
I am using the official debian with LCNC 2.8.4
www.linuxcnc.org/iso/linuxcnc-2.8.4-buster.iso
another thing you can try, what helped me.
open terminal
> poetry shell
open terminal
> poetry shell
Last edit: 3 years 3 months ago by deroj.
- RiJa
3 years 3 months ago - 3 years 3 months ago #275263
by RiJa
Thank you, that helped. But after flashing the board and trying to check with hal im getting this error:
[/code]
[code]halcmd: loadrt litexcnc_eth connection_string="eth:10.0.0.10"
litexcnc: loading litexCNC etherbone driver version 1.0.0
failed to resolve remote socket address (err=-8 / Servname not supported for ai_socktype)
LitexCNC-eth: ERROR: failed to connect to board on 'eth:10.0.0.10'
rtapi_app: caught signal 11 - dumping core
<stdin>:2: waitpid failed /usr/bin/rtapi_app litexcnc_eth
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for litexcnc_eth failed, returned -1
Removing the eth: doesn't work either.
Last edit: 3 years 3 months ago by RiJa.
- deroj
3 years 3 months ago #275264
by deroj
Can you Ping the Board unser this IP?
- RiJa
3 years 3 months ago - 3 years 3 months ago #275270
by RiJa
cnc@debian:~$ ping 10.0.0.10
PING 10.0.0.10 (10.0.0.10) 56(84) bytes of data.
From 10.0.0.15 icmp_seq=1 Destination Host Unreachable
From 10.0.0.15 icmp_seq=2 Destination Host Unreachable
From 10.0.0.15 icmp_seq=3 Destination Host Unreachable
From 10.0.0.15 icmp_seq=4 Destination Host Unreachable
From 10.0.0.15 icmp_seq=5 Destination Host Unreachable
From 10.0.0.15 icmp_seq=6 Destination Host Unreachable
From 10.0.0.15 icmp_seq=7 Destination Host Unreachable
From 10.0.0.15 icmp_seq=8 Destination Host Unreachable
From 10.0.0.15 icmp_seq=9 Destination Host Unreachable
From 10.0.0.15 icmp_seq=10 Destination Host Unreachable
- deroj
3 years 3 months ago #275273
by deroj
So when you cannot ping it, LinuxCNC wouldn't find it either....
Do you use the left or right LAN port from the board?
Only one will work.
And is 10.0.0.10 the IP address you set in the JSON config?
Only one will work.
Time to create page: 0.156 seconds
