ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
3 years 3 months ago #276689 by rthorntn
My boards arrived and they're all v8.2, has anyone got an v8.2 working?
Thanks!
  • Platinum Member
  • Platinum Member
3 years 3 months ago #276691 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Like I advised you before, the best place to raise this issue will be at:
github.com/q3k/chubby75/tree/master
github.com/enjoy-digital/litex
Chubby75 is the project that has been reverse engineering the boards.
And Litex is the project that has the build infrastructure.
3 years 2 months ago #276700 by wuyatom
  Hello, why does it crash when I open Linuxcnc after adding the stepgen module to my json configuration file?
3 years 2 months ago #276701 by wuyatom
My IPL board is 5A-75E8.0, and the firmware generated with version 6.0 will be fine if you don’t add stepgen to the configuration file to generate the firmware
  • Platinum Member
  • Platinum Member
3 years 2 months ago #276706 by Cant do this anymore bye all
If you use the main branch you should be ok.
That's a known issue with the 11-add-external-extensions-to-litexcnc branch. It happens on both 2.8 & 2.9 branches of Linuxcnc.
The best idea will be to keep a watch on this thread:
github.com/Peter-van-Tol/LiteX-CNC/issues/28
3 years 1 month ago #281272 by DHeineck
Dredging this one out of the archives -- how are people getting on with this hardware/firmware solution? I'd love to play around with this on a 3020  router with your usual steppers, limit sensors, EMO, and maybe a 0-10V for spindle. Is there a config that works for this use case?
Moderators: PCW, jmelson
Time to create page: 0.480 seconds
