ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
  • Platinum Member
  • Platinum Member
3 years 1 month ago - 3 years 1 month ago #281276 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Pete's been making some great progress. He's working on a SPI version for the RPi for those that want that option.
I'm just uploading an image for the RPi with LitexCNC drivers and tools to build firmware, yes it does include Linuxcnc v2.9.
If you wander over to github.com/Peter-van-Tol/LiteX-CNC and read the discussions section you'll find out more.
Link to image. User name & passwd in text file in google drive folder
drive.google.com/file/d/1PvfQPvsrcP9Ss2Z...A4P/view?usp=sharing
Last edit: 3 years 1 month ago by Cant do this anymore bye all. Reason: add link
The following user(s) said Thank You: DHeineck, kzali, TOLP2
3 years 1 month ago #281350 by deroj
Yes. It is working very good. Maybe perfect :side:
I use it for my lathe and for a 3 axis mill.
pwm output is used to generate 0-10V signal for the vfd of the mill.
on the lathe I use a 10.000ppr spindle encoder with high frequency optocouplers, which works perfect.
G76, G33 cycles and constant surface speed - no problems.
Finished already about 400 parts on my lathe. And this with a buggy version of litexcnc. And this bug is solved now :woohoo:
Peter did a great job the last weeks
The following user(s) said Thank You: DHeineck, kzali, Cant do this anymore bye all
3 years 1 month ago #281360 by deroj
Please fell free to download my maschine setup.
It includes the setup for my lathe.
There are 4 stepgens available.
2 Encoders with A, B, Z inputs
3 PWM channels
general GPIOs
Communication to VFD via modbus, mb2hal component.
in the firmware folder are the config JSON and the prebuilt bitfile.
It uses colorlight 5A-75B board
Ip address 192.168.178.150
You can add or change to your needs. Think this is a good basic to start.
The following user(s) said Thank You: DHeineck, TOLP2, svb
3 years 1 month ago #281395 by DHeineck
Thank you both for the update! (and Peter, for that matter)
The following user(s) said Thank You: TOLP2
3 years 2 weeks ago #283138 by TOLP2
I took the development of Litex-CNC to a new topic .Feel free to post suggestions and questions in that topic, or post them on the Github Discussions .
The following user(s) said Thank You: tommylight, svb
2 years 10 months ago - 2 years 10 months ago #287330 by KlimukVI
Board models  RV901  ,  5A-75E  .
There are also models for  MRV336  ,  7i96  .
I hope this will be useful to some.
Last edit: 2 years 10 months ago by KlimukVI.
Moderators: PCW, jmelson
Time to create page: 0.208 seconds
