Mesa 7i92+7i76+7i85S
- Artur_1617
- Thank you received: 5
10 Sep 2022 09:30 #251606
by Artur_1617
Mesa 7i92+7i76+7i85S was created by Artur_1617
start to connect this setup for my lathe.
First problem about wiring
7i92 connect to 7i76 without problem.
But 7i92 to 7i85S I have problem. Buy separatery idc connector with cable and Dsub for connect with them.
Please look the foto and tell me this connection is ok?
- Thank you received: 5325
10 Sep 2022 13:18 #251613
Replied by PCW on topic Mesa 7i92+7i76+7i85S
That looks correct, what problem do you have?
- Artur_1617
11 Sep 2022 10:00 - 11 Sep 2022 11:43 #251673
by Artur_1617
Replied by Artur_1617 on topic Mesa 7i92+7i76+7i85S
I connected and for now all working.
Last edit: 11 Sep 2022 11:43 by Artur_1617.
- Artur_1617
11 Sep 2022 16:51 - 11 Sep 2022 17:49 #251687
by Artur_1617
After install linuxcnc 2.8.2 want change network settings for 7i92 but is instaled nm-tray and when want open settings dont do anything.
Want install gnome but when write in terminal
apt-get install network-manager network-manager-gnome
Got E; unable to locate package network-manager-gnome
When try
apt-get update after
When try
Last edit: 11 Sep 2022 17:49 by Artur_1617.
11 Sep 2022 17:06 #251689
I would probably side-step the GUI network tools and setup the real time link
by editing the interfaces file as explained in the hm2_eth manual page
man hm2_eth
man hm2_eth
- Artur_1617
11 Sep 2022 17:37 - 11 Sep 2022 17:58 #251692
by Artur_1617
Forget write
ifconfig and iwconfig didint work to...
After add to file interfaces;
auto eth1
iface eth1 inet static
address 192.168.1.1
hardware-irq-coalesce-rx-usecs 0
and try mesaflash --device 7I92
Got No 7i92 board found
auto eth1
address 192.168.1.1
Last edit: 11 Sep 2022 17:58 by Artur_1617.
11 Sep 2022 18:19 #251693
What does
ip a
report?
ip a
report?
- Artur_1617
11 Sep 2022 18:29 #251694
by Artur_1617
edi@debian:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 08:2e:5f:20:95:65 brd ff:ff:ff:ff:ff:ff
inet 192.168.137.155/24 brd 192.168.137.255 scope global dynamic noprefixroute eno1
valid_lft 604766sec preferred_lft 604766sec
inet6 fe80::a2e:5fff:fe20:9565/64 scope link noprefixroute
11 Sep 2022 18:33 #251695
Right, so the actual Ethernet device name is eno1, not eth1
- Artur_1617
11 Sep 2022 18:46 #251696
by Artur_1617
After change eth1 to eno1 in interfaces file
still mesaflash --device 7i92 No board found
