Mesa 7i92+7i76+7i85S
- Thank you received: 5334
06 Oct 2022 15:29 #253615
Replied by PCW on topic Mesa 7i92+7i76+7i85S
Have you checked for backlash?
- Artur_1617
06 Oct 2022 17:12 #253626
by Artur_1617
Replied by Artur_1617 on topic Mesa 7i92+7i76+7i85S
Backlash is about 0.01
07 Oct 2022 12:47 #253684
Can you post a halscope plot of the error?
- Artur_1617
23 Oct 2022 08:33 #254833
by Artur_1617
For now I start to working without scales.
But need spindle encoder for tapping.
The encoder is connected to 7i85 to third encoder input.
But dont see any signal from them in halmeter ( encoder04).
The encoder is 12V power supply and GND is connected with GND power supply from mesa card.
Encoder give 0-3V
Encoder give 0-3V
23 Oct 2022 14:23 #254855
Encoder 04 would be on the 7I76
- Artur_1617
23 Oct 2022 14:40 #254856
by Artur_1617
In halmeter
I look on encoder 0, 1, 2 ,3 ,4 and dont see any change moving encoder...
Which encoder should look?
23 Oct 2022 14:58 #254858
With your current firmware, Encoders 0..3 are on the 7I85S,
and encoder 4 is on the 7I76.
If you have a single ended encoder, you need to jumper its
inputs for single-ended = TTL mode
- Artur_1617
23 Oct 2022 16:36 #254864
by Artur_1617
Firmare forum.linuxcnc.org/media/kunena/attachme.../7i92_7i76_7i85D.zip
Jumper is ok.
Now the first encoder on 7i85s is encoder02 the second is encoder03 and working.
Jumper is ok.
23 Oct 2022 21:37 #254869
If you have a 7I85S, that is incorrect firmware (its for a 7I85)
- Artur_1617
24 Oct 2022 06:35 - 24 Oct 2022 06:37 #254883
by Artur_1617
Please give me correct bit file for linuxcnc 2.81. The bit file you used has stepgen features that are not supported in LinuxCNC 2.8
Here is a 2.8 compatible 7I76+7I85 bitfile:
Last edit: 24 Oct 2022 06:37 by Artur_1617.
Time to create page: 0.163 seconds
