Mesa 7i92+7i76+7i85S
  • Artur_1617
  • Artur_1617's Avatar Topic Author
  • Elite Member
  • Elite Member
11 Nov 2022 19:00 #256456 by Artur_1617
Replied by Artur_1617 on topic Mesa 7i92+7i76+7i85S
11 Nov 2022 20:24 #256460 by PCW
Replied by PCW on topic Mesa 7i92+7i76+7i85S
Bitfile for 7I92+7I76+7I85S:
File Name: 7i92_7i76_7i85sd.zip
File Size:125 KB
encoders 0..3 on 7I85S
encoder 4 on 7I76
stepgens 0..4 on  7I76
stepgens 5..7 on 7I85S
  • Artur_1617
  • Elite Member
  • Elite Member
20 Dec 2022 15:41 #259960 by Artur_1617
Still not lucky with spindle encoder.
For me now I have one encoder on 7i76 and two on 7i85s but need 3 encoders inputs on 7i85s
After reflash bit file.
Mesaflash give
Configuration pin-out:
IO Connections for P2
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func
Pin Dir
 1      0   IOPort       StepGen          0        Dir/Table2
(Out)
14      1   IOPort       StepGen          0        Step/Table1
(Out)
 2      2   IOPort       StepGen          1        Dir/Table2
(Out)
15      3   IOPort       StepGen          1        Step/Table1
(Out)
 3      4   IOPort       StepGen          2        Dir/Table2
(Out)
16      5   IOPort       StepGen          2        Step/Table1
(Out)
 4      6   IOPort       StepGen          3        Dir/Table2
(Out)
17      7   IOPort       StepGen          3        Step/Table1
(Out)
 5      8   IOPort       StepGen          4        Dir/Table2
(Out)
 6      9   IOPort       StepGen          4        Step/Table1
(Out)
 7     10   IOPort       SSerial          0        TXData0
(Out)
 8     11   IOPort       SSerial          0        RXData0
(In)
 9     12   IOPort       SSerial          0        TXData1
(Out)
10     13   IOPort       SSerial          0        RXData1
(In)
11     14   IOPort       MuxedQCount      0        MuxQ-IDX
(In)
12     15   IOPort       MuxedQCount      0        MuxQ-B
(In)
13     16   IOPort       MuxedQCount      0        MuxQ-A
(In)
IO Connections for P1
Pin Dir
 1     17   IOPort       SSerial          0        RXData6
(In)
14     18   IOPort       SSerial          0        TXData6
(Out)
 2     19   IOPort       SSerial          0        RXData5
(In)
15     20   IOPort       SSerial          0        TXData5
(Out)
 3     21   IOPort       SSerial          0        RXData4
(In)
16     22   IOPort       SSerial          0        TXData4
(Out)
 4     23   IOPort       SSerial          0        RXData3
(In)
17     24   IOPort       SSerial          0        TXData3
(Out)
 5     25   IOPort       SSerial          0        RXData2
(In)
 6     26   IOPort       SSerial          0        TXData2
(Out)
 7     27   IOPort       MuxedQCountSel   2        MuxSel0
(Out)
 8     28   IOPort       MuxedQCount      1        MuxQ-A
(In)
 9     29   IOPort       MuxedQCount      1        MuxQ-B
(In)
10     30   IOPort       MuxedQCount      1        MuxQ-IDX
(In)
11     31   IOPort       MuxedQCount      2        MuxQ-A
(In)
12     32   IOPort       MuxedQCount      2        MuxQ-B
(In)
13     33   IOPort       MuxedQCount      2        MuxQ-IDX
(In)
20 Dec 2022 17:12 #259968 by PCW
That should give you 5 encoders:
7I76 encoder 0
7I85S encoders 2..5
  • Artur_1617
  • Elite Member
  • Elite Member
20 Dec 2022 19:59 #259977 by Artur_1617
With this setup
If moving X axis i see move on encoder0 in halmeter
If moving Z axis i see move on encoder1 in halmeter
And dont see any move on encoders 2, 3, 4 when turn spindle encoder...
I have conected encoders to 7i85s:
0 is X axis
1 is Z axis
2 is spindle encoder
20 Dec 2022 20:49 - 21 Dec 2022 02:19 #259978 by PCW
1. First make sure you have the correct firmware for a 7I76 and a 7I85S
(7i92_7i76_7i85sd.bit is correct for a 7I92 with a 7I76 on P2 and a 7I85S on P1)
(your mesaflash listing shows a 7I76+7I85 configuration)
2. Does the spindle encoder work on 7I85S encoder inputs 0,1?
3. Have you verified  the cable connections from the 7I92 P1 to the 7I85S
 Non-working encoders might indicate a cable issue.
EDIT: I just tested 7i92_7i76_7i85sd.bit with a 7i92 and a 7I85S and encoder inputs 0..3 on the 7I85S work as expected.
bitfile md5checksum e0d874fe7e4c76072f763b2e837302d4
This is the mesaflash readhmid listing of 7i92_7i76_7i85sd.bit with the daughterboard info:
mesaflash --device 7i92 --addr 10.10.10.10 --readhmid --dbname1 7i76 --dbname2 7i85s > 7i92_7i76_7i85sd.txt
File Name: 7i92_7i76_7i85sd.txt
File Size:5 KB
Last edit: 21 Dec 2022 02:19 by PCW.
Moderators: PCW, jmelson
Time to create page: 0.136 seconds
