Mesa 7i92+7i76+7i85S
- Thank you received: 5312
14 Sep 2022 19:28 - 14 Sep 2022 19:29 #251928
Replied by PCW on topic Mesa 7i92+7i76+7i85S
The encoder A/B/Index pins are not really useful in hal
You would normally use the encoder position (for feedback)
index-enable (for synchronized motion) or the encoder counts
(if used for jogging)
Typically you would use the 7I76 MPG inputs rather than the 7I85S
encoder pins for a MPG
Last edit: 14 Sep 2022 19:29 by PCW.
- Artur_1617
14 Sep 2022 19:41 - 14 Sep 2022 19:50 #251929
by Artur_1617
Replied by Artur_1617 on topic Mesa 7i92+7i76+7i85S
Now one move of Mpg give 4counts in halmeter is ok?
Change jumpers dont change number of counts.
Mpg outputs A,A/ , B,B/
I only test my config with Mpg conecting to 7i85 becouse dont have here linear scales for testing inputs...
Last edit: 14 Sep 2022 19:50 by Artur_1617.
14 Sep 2022 19:54 #251931
Yes, the standard encoders do not have the 1X mode often used
with MPGs so you would expect 4X the encoder PPR
(this is why you would normally use the 7I76 MPG inputs as these support a 1X mode)
- Artur_1617
16 Sep 2022 08:27 #252068
by Artur_1617
Now fighting with spindle out.
Try in Pncconf add 7i92 with one 7i76 and on Tb4 add spindle out 0-10v and copy that in my hal file for spindle make me error
tokarka.hal:232: parameter or pin 'hm2_7i92.0.7i76.0.0.spinout-minlim' not found
Now in hall is hm2_7i92.0.spinout-minlim without 7i76 becouse in other settings for axis dont apeard any 7i76 and try this.
Actual hal and ini
Actual hal and ini
16 Sep 2022 17:31 #252092
Do you have field power applied to the 7I76?
- Artur_1617
16 Sep 2022 18:50 #252099
by Artur_1617
Yes
Tb1
Pin1 24V
Pin8 Gnd
W1 left
Tb1
Pin1 24V
Pin8 Gnd
W1 left
16 Sep 2022 19:25 #252101
Sorry I missed the original error:
There is no such pin
That should be hm2_7i92.0.7i76.0.0.spinout-minlim
- Artur_1617
16 Sep 2022 19:27 #252102
by Artur_1617
I try this to and dont work
16 Sep 2022 19:44 #252107
Can you post linuxCNCs startup messages here?
(start LinuxCNC from the command line)
Do you have 5V and field power on the 7I76? that is, both Yellow LEDs on?
- Artur_1617
17 Sep 2022 06:33 #252141
by Artur_1617
Yes I have connected 5V and 24V and both Leds on.
Time to create page: 0.720 seconds
