Mesa hm2/hm2_7i96s.0: error finishing read
3 years 11 months ago #256229 by JT
My /etc/network/interfaces
auto lo iface lo inet loopback auto enp9s0 iface enp9s0 inet static address 10.10.10.11 netmask 255.255.255.0 hardware-irq-coalesce-rx-usecs 0
JT
3 years 11 months ago #256230 by PCW
I wonder if you are being affected by the RTK driver issue rodw mentioned.
3 years 11 months ago #256233 by scotth
Running 5.19.0-2-rt-amd64 #1 SMP PREEMPT_RT Debian 5.19.11-1 (2022-09-24) x86_64 x86_64 x86_64 GNU/Linux.
Using the patch Rodw recommended.
forum.linuxcnc.org/27-driver-boards/4691...ead?start=130#256114
No failure in 24 hours of running.
3 years 11 months ago #256240 by rodw
I gave up on getting the kernel compiled and upgraded to bookworm 6.0. I have a win!
Discussed here
forum.linuxcnc.org/9-installing-linuxcnc...9-13?start=10#256235
I still don't understand why ping times are way high with isolcpus=2,3 but the tmax values are awesome. No finishing read errors after an hour or so. and no real time delays.
Its clearly to do with network drivers.
3 years 11 months ago #256246 by rodw
I didn't have IRQ coalescing disabled because I thought that was only for Intel ethernet controllers.
john@cave:~$ lspci | egrep -i 'network|ethernet' 07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06) 09:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 04) [code][code]JT
[/code][/code]
The cards are always the same old suspects.
What drivers are installed for them?
Which one is the mesa card? sudo lshw -class networkorethtool -i eth0I know I've broken stuff for you before but the Odroid guys say to build the R8125 driver from the realtek source
The other one should be using the r8168-dkms driver
I wonder if we should be black listing existing drivers to get the R8168-dkm driver installed?
3 years 11 months ago #256266 by rodw
My Brix was left on all day while I was at work and not one error finishing read showed up!
So I am trying again to compile the 6.1 kernel on i3 but its failing very early in the build. I am starting from the 6.0 kernel non-realtime and preempt_rt both fail,
First I needed to add a few more dependencies
sudo apt install build-essential bin86 #libncurses5-dev pkg-config libssl-dev flex bison qtbase5-dev openssl libelf-dev
Then I got
  CC      /home/debian/devel/rtlinux/linux-6.1-rc3/tools/bpf/resolve_btfids/str_error_r.o   LD      /home/debian/devel/rtlinux/linux-6.1-rc3/tools/bpf/resolve_btfids/resolve_btfids-in.o   LINK     resolve_btfids make: *** [Makefile:1254: scripts] Error 2 make: *** Waiting for unfinished jobs....
This article says its possible to build a deb with
make -j $(nproc) deb-pkg
Perhaps somebody how has got this working could try building the deb. That would be more useful in the long term. The article says how to install it too
[code]for pkg in ./*.deb; do sudo dpkg -i $pkg; done
[/code]
It would be cool if we could offer a packaged deb. Hosted in Google Drive or something.
Moderators: PCW, jmelson
