System:
Kernel: 5.10.0-19-rt-amd64 x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: Cinnamon 5.4.12
tk: GTK 3.24.33 wm: Mutter dm: LightDM Distro: Linux Mint 21 Vanessa base: Ubuntu 22.04 jammy
Machine:
Type: Laptop System: Apple product: Macmini6,1 v: 1.0 serial: <superuser required> Chassis:
type: 16 v: Mac-031AEE4D24BFF0B1 serial: <superuser required>
Mobo: Apple model: Mac-031AEE4D24BFF0B1 v: Macmini6,1 serial: <superuser required> UEFI: Apple
v: 421.0.0.0.0 date: 12/17/2020
CPU:
Info: dual core model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge rev: 9 cache:
L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2893 min/max: 1200/3100 cores: 1: 2893 2: 2893 3: 2893 4: 2893
bogomips: 19954
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915 v: kernel ports:
active: HDMI-A-3 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting unloaded: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96
Monitor-1: HDMI-3 mapped: HDMI-A-3 model: Philips 220X res: 1680x1050 dpi: 90
diag: 552mm (21.7")
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 22.0.5 compat-v: 3.1
direct render: Yes
Audio:
Device-1: Intel 7 Series/C216 Family High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1e20
Sound Server-1: ALSA v: k5.10.0-19-rt-amd64 running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3 v: kernel pcie:
speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0 chip-ID: 14e4:1686
IF: enp1s0f0 state: down mac: <filter>
Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme driver: bcma-pci-bridge
v: N/A pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:4331
IF-ID-1: wlp2s0b1 state: up mac: <filter>
Bluetooth:
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8 bus-ID: 3-1.8.1.3:8
chip-ID: 05ac:828a
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 2.1 lmp-v: 4.0
sub-v: 4196
Drives:
Local Storage: total: 269.64 GiB used: 37.42 GiB (13.9%)
ID-1: /dev/sda vendor: Crucial model: CT250BX100SSD1 size: 232.89 GiB speed: 6.0 Gb/s
serial: <filter>
ID-2: /dev/sdb type: USB vendor: SanDisk model: Cruzer Blade size: 29.25 GiB serial: <filter>
ID-3: /dev/sdc type: USB vendor: Generic model: Flash Disk size: 7.5 GiB serial: <filter>
Partition:
ID-1: / size: 227.68 GiB used: 35.09 GiB (15.4%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 5.2 MiB (1.0%) fs: vfat dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 512 KiB (0.0%) priority: -2 file: /swapfile
Sensors:
System Temperatures: cpu: 94.0 C mobo: N/A
Fan Speeds (RPM): N/A
Repos:
Packages: apt: 2217
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/balena-etcher.list
1: deb [signed-by=/usr/share/keyrings/balena-etcher-archive-keyring.gpg] https: //dl.cloudsmith.io/public/balena/etcher/deb/linuxmint vanessa main
2: deb-src [signed-by=/usr/share/keyrings/balena-etcher-archive-keyring.gpg] https: //dl.cloudsmith.io/public/balena/etcher/deb/linuxmint vanessa main
Active apt repos in: /etc/apt/sources.list.d/danielrichter2007-grub-customizer-jammy.list
1: deb http: //ppa.launchpad.net/danielrichter2007/grub-customizer/ubuntu jammy main
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http: //mirror.wiru.co.za/linuxmint-packages vanessa main upstream import backport
2: deb http: //mirror.wiru.co.za/ubuntu jammy main restricted universe multiverse
3: deb http: //mirror.wiru.co.za/ubuntu jammy-updates main restricted universe multiverse
4: deb http: //mirror.wiru.co.za/ubuntu jammy-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Info:
Processes: 267 Uptime: 15m Memory: 3.75 GiB used: 1.7 GiB (45.5%) Init: systemd v: 249
runlevel: 5 Compilers: gcc: 11.3.0 alt: 11 Client: Cinnamon v: 5.4.12 inxi: 3.3.13
