Mesa hm2/hm2_7i96s.0: error finishing read
3 years 10 months ago #259105 by JT
There must be more at work here than just Ping times. John's are very good.
Did you see my max time?0.407
JT
3 years 10 months ago #259135 by rodw
overnight no errors . Since your longer run anyway
packing@packing:~$ halcmd show param hm2*tmax* Parameters: Owner   Type  Dir         Value  Name     93  s32   RW              0  hm2_7i76e.0.read-request.tmax     93  bit   RO          FALSE  hm2_7i76e.0.read-request.tmax-increased     93  s32   RW         909760  hm2_7i76e.0.read.tmax     93  bit   RO          FALSE  hm2_7i76e.0.read.tmax-increased     93  s32   RW         489900  hm2_7i76e.0.write.tmax     93  bit   RO          FALSE  hm2_7i76e.0.write.tmax-increased
Ping times
64 bytes from 10.10.10.10: icmp_seq=19 ttl=64 time=0.455 ms 64 bytes from 10.10.10.10: icmp_seq=20 ttl=64 time=0.425 ms 64 bytes from 10.10.10.10: icmp_seq=21 ttl=64 time=0.434 ms 64 bytes from 10.10.10.10: icmp_seq=22 ttl=64 time=0.498 ms 64 bytes from 10.10.10.10: icmp_seq=23 ttl=64 time=0.500 ms 64 bytes from 10.10.10.10: icmp_seq=24 ttl=64 time=0.510 ms 64 bytes from 10.10.10.10: icmp_seq=25 ttl=64 time=0.465 ms ^C --- 10.10.10.10 ping statistics --- 25 packets transmitted, 25 received, 0% packet loss, time 24366ms rtt min/avg/max/mdev = 0.245/0.465/0.698/0.074 ms packing@packing:~$
max ping time = 0.510
*-network description: Ethernet interface product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:03:00.0 logical name: enp3s0
Ahh, on this PC, the change to the driver actually stuck
packing@packing:~$ sudo ethtool -i enp3s0 driver: r8168 version: 8.050.03-NAPI
Something odd happened as the driver was rebuilt when I changes linux-headers, not when I installed the driver.
Then it worked...
PS. not playing with this one anymore!
3 years 10 months ago #259136 by tommylight
Nope, max ping time 0.698.
Usually the first one or two replies are longer, then settle.
min/ avg/ max/ mdev
3 years 10 months ago #259137 by tommylight
3 years 10 months ago #259140 by rodw
min/ avg/ max/ mdev
Tommy, yses .510 is after the first slower ping.
But the point is pings are  worse than Johns and does not get an error finishing read and TMAX values are way lower...
The queston is why?
3 years 10 months ago #259144 by tommylight
I would venture a guess at the way the driver requests interrupts to hardware, but i am not willing to go deep into that, especially since you already did a lot of work in figuring out solutions and what drivers work, so thank you for the time and effort you put into it.
Did anyone try ping with bigger frames/packets?
Pretty sure the size will mess response times quickly on the kernels with issues.
Or maybe, just maybe there is something wrong in those kernels in the way they handle UDP transport?
Ping is TCP/IP/ICMP, Mesa uses UDP if i am not mistaken, and so did Quake 3, the game. Quake had a way to switch to TCP/IP but that was laggy as hell with the limited bandwidth we had.
Moderators: PCW, jmelson
Time to create page: 0.144 seconds
