Mesa hm2/hm2_7i96s.0: error finishing read
3 years 11 months ago #257009 by zack
ok atheros had some realtime issues back in the day as well, what would be a suggested MAC, intel?
3 years 11 months ago #257024 by tommylight
I reported a few posts back that Intel works with new kernels.
Still some Intel NIC need coalescing set to 0, but i never needed that.
ASUS ROG Crosshair VIII Impact - AMD X570
3 years 11 months ago #257036 by arvidb
As established some pages back (e.g. here and here - again with an e1000e Intel NIC) this problem is not specific to Realtek NICs. And "new" kernels (as in 5.10) does not always work with Intel NICs.
The issue seems to have something to do with the way the Debian kernel is configured, or with some Debian-specific kernel patches, and not with a specific NIC manufacturer. While the problem might go away with a different NIC, no-one has of yet established the exact cause for the problem so changing NICs will be hit-and-miss. What does seem to work is building your own vanilla+rt-patched kernel.
If someone had time to build their own kernel from Debian sources, that would be an interesting test to narrow the cause down further.
3 years 11 months ago #257056 by rodw
Debian documents how to build their kernel here
kernel-team.pages.debian.net/kernel-hand...ml#s-common-official
One day I might gather the courage. It would be interesting to see what has changed between it and the upstream kernel
3 years 10 months ago #259017 by JT
I just built the 6.0.5-rt14 #2 SMP PREEMPT_RT kernel and still get hm2/hm2_7i92.0: error finishing read! iter=3481476.
Debian 12 Manufacturer: ASUSTeK COMPUTER INC. Product Name: TUF GAMING B550-PRO Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06) Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 04) john@cave:~$ lscpu Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Address sizes: 48 bits physical, 48 bits virtual Byte Order: Little Endian CPU(s): 12 On-line CPU(s) list: 0-11 Vendor ID: AuthenticAMD Model name: AMD Ryzen 5 5600X 6-Core Processor CPU family: 25 Model: 33 Thread(s) per core: 2 Core(s) per socket: 6 Socket(s): 1 Stepping: 2 Frequency boost: enabled CPU(s) scaling MHz: 95% CPU max MHz: 4650.2920 CPU min MHz: 2200.0000
JT
3 years 10 months ago #259025 by JT
And I just checked and I have the driver Realtek RTL8125 firmware (rtl_nic/rtl8125a-3.fw) for my NIC. Good thing I don't "need" RT to work on this PC.
JT
Moderators: PCW, jmelson
Time to create page: 0.567 seconds
