Mesa hm2/hm2_7i96s.0: error finishing read
- bensttech
- Thank you received: 8
16 Oct 2022 23:07 #254292
by bensttech
Replied by bensttech on topic Mesa hm2/hm2_7i96s.0: error finishing read
GRUB_CMDLINE_LINUX_DEFAULT="quiet lapic=notscdeadline hpet=disable i915.i915_enable_rc6=0 i915.powersave=0 intel_idle.max_cstate=1 processor.max_cstate=1 isolcpus=1 idle=poll"
That little lot significantly improves things it makes much more stable, it reduces the frequency and magnitude of the big delay spikes.
- Thank you received: 5321
17 Oct 2022 01:40 #254301
Replied by PCW on topic Mesa hm2/hm2_7i96s.0: error finishing read
You might also try running Intels powertop utility and setting all power saving options to "bad"
- bensttech
17 Oct 2022 06:09 #254312
by bensttech
So extending the servo period does not seem to overcome the issues as the read.tmas also extends when the timing spikes occur, i left it on soak test overnight and sure enough i got an "error finishing read! iter=" my read hm2_7i95.0.read.tmax hit a record 3376032 and servo .tmax hit 3597792 both with servo period set to SERVO_PERIOD = 2000000 I will try the exact hw with my older 2.8 build and also some different hw with this setup and post the results. Is it possible to make the error finishing read non fatal?
- bensttech
17 Oct 2022 09:36 #254320
by bensttech
The issue follows the OS / Kernel or LinuxCNC version, not the hardware (hardware has small effect). Will post the stats later.
17 Oct 2022 15:21 - 17 Oct 2022 15:28 #254334
"Error finishing read" means that too many successive timeouts have occurred
Default settings are: timeout means >80% of the servo period,
and 5 timeouts in a row result in a fatal I/O error: "error finishing read"
You can tune the controlling parameters:
hm2_7i96s.0.packet-read-timeout (default = 80%)
hm2_7i96s.0.packet-error-increment (default = 2)
hm2_7i96s.0.packet-error-decrement (default = 1)
hm2_7i96s.0.packet-error-limit (default=10)
Last edit: 17 Oct 2022 15:28 by PCW.
- bensttech
17 Oct 2022 17:22 #254342
by bensttech
many thanks, is the packet-error exposed to hal at all i was struggling to see it.
17 Oct 2022 17:28 - 17 Oct 2022 17:37 #254343
Yes:
hm2_7i96s.0.packet-error-exceeded
hm2_7i96s.0.packet-error-level
Note that packet-error can be useful to prevent bogus velocity corrections
in the case of lost/dropped packets:
# position command and feedback
net emcmot.00.pos-cmd joint.0.motor-pos-cmd => pid.0.command mux2.0.in1
net stepgen0fb hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-fb mux2.0.in0
net motor.00.pos-fb <= mux2.0.out joint.0.motor-pos-fb pid.0.feedback
net motor.00.command pid.0.output hm2_[HOSTMOT2](BOARD).0.stepgen.00.velocity-cmd
net ioerror hm2_[HOSTMOT2](BOARD).0.packet-error mux2.0.sel
This hal section uses the packet error pin to select the commanded position
rather that the [stale] feedback position for loop feedback in the event of packet
loss
loss
Last edit: 17 Oct 2022 17:37 by PCW.
The following user(s) said Thank You: arvidb, tommylight, bensttech
- bensttech
17 Oct 2022 19:14 #254351
by bensttech
Ok so next steps? There are still to many variables to figure out if its kernel or linuxcnc its self.
Has anyone got 2.9 running a mesa Ethernet card 7i95 or 96 etc stably?
I looked at building 2.8 for deb-11 to see if its in CNC or the OS but i looks like this is not really possible.
I looked at getting the 4.19 series kernel in deb-11 and that is not easy either, would have to be a source config and build.
- Thank you received: 7468
17 Oct 2022 20:30 #254355
Replied by tommylight on topic Mesa hm2/hm2_7i96s.0: error finishing read
No need to build anything, here you go
packages.debian.org/buster/amd64/linux-i...22-rt-amd64/download
The following user(s) said Thank You: arvidb, bensttech
17 Oct 2022 21:04 #254366
Yes 4.19 is a better choice on most hardware but
5.10 and 6.0 work for me on my test CPU (HP Elite 800).
I dont think the LinuxCNC version is related as there have been no
significant upper level driver changes to hm2_eth for quite a while
( Though this reminds me that I should add and accumulated error count )
Time to create page: 0.265 seconds
