- Thank you received: 158
I don't know. This article says otherwise.I doubt it will become standard, ever, as it has to stop plenty of functions used for power saving, and since the era of PC domination is over, laptops and tablets rule now.
Using Preempt-RT on laptops a lot, so i know they use much more power and heat a lot more with it. On most when RT is in use running LinuxCNC the processor will remain at max speed (not turbo) all the time.
When I looked around for a used 8300, there were two types. Conventional desktop and an All in one. I wonder if that is the difference?Right, but 5.10 works OK on my 8300
That's why I was asking about bensttech's 8300,
as it seems possible to run 5.X kernels without these huge
latency spikes. That is, what is the difference between my
8300 and bensstechs?
