Question about custom BOB for a 7i92
3 years 5 months ago #271697 by blazini36
Replied by blazini36 on topic Question about custom BOB for a 7i92
What do these inputs or outputs do? maybe there is some,
firmware module that can do the  faster I/O manipulation
[url] drive.google.com/file/d/1axmgOS7w0YXyVlB...81I/view?usp=sharing [/url]
The video kind of explains it best I suppose. In this case the input comes from a contrast sensor. That resets the encoder position and sets pins on a custom hal component that performs a modulo operation. When the encoder position is >= the component's position setting it triggers and output to the camera, then allows the encoder to be reset again on the next input
I did this test just to see how accurate the whole thing is:
[url] drive.google.com/file/d/14sGXzeZkgIF1WY5.../view?usp=share_link [/url]
That's a camera and it's strobe pointed at a 2" OD roller. It's being triggered from the same contrast sensor and encoder. By the end the roller is spinning over 2k rpms.  There's a scenario where it uses an encoder index as the input instead of the contrast sensor.
The biggest bottleneck is obviously the software hal component and in practice it doesn't matter that much as long as all delays are consistent. If it were practical the whole thing would run as a FPGA firmware module rather than passing back and forth into hal. Still the faster I can read that input, run the component and trigger the output the better.
3 years 5 months ago #271706 by PCW
Replied by PCW on topic Question about custom BOB for a 7i92
It sounds like that could be done with an extension of the encoder module
(and be accurate to 1 count)
3 years 5 months ago #271717 by andypugh
Replied by andypugh on topic Question about custom BOB for a 7i92
I don't suppose the hm2 sources are still available?
They are in a zip file in this zip file:
www.mesanet.com/software/parallel/7i92.zip
3 years 5 months ago #271794 by blazini36
I figured that, unfortunately VHDL is about as Chinese as C or anything else to me.
If at some point in the future I knew someone who could modify the encoder module. Besides the logic, for a card like the 7i96 it would need to be able to address an extra input and output from within the module right? Would that be possible with a 7i96? I'm not sure if the IO is muxed or anything on that card.
3 years 5 months ago #271795 by PCW
Nothing is muxed on the 7I96/7I96S
If this is done at high speeds could a variable delay be sufficient?
(a variable delay with 10 ns resolution can be done with the oneshot module)
3 years 5 months ago #271796 by blazini36
The 2nd revision looks about ready but I figured I should post the drawing of the SPI decoder and input multiplexer to make sure I didn't get anything wrong.
I wasn't able to do much with SPI on the first rev because of the missing component and that PCB mistake. One question I have is if the 7i92 IO is strong enough to drive the SCK for 5 devices on board with no buffer or anything? I dropped the external SPI port idea, it was getting a bit out of hand.
I have the 4 ADCs that only output so they don't use MOSI, and I added a small 8bit MCU as the stepper drives I'll be using need configuration over UART, that is connected to the 7i92's BSPI instance and is the only thing on MOSI. I think my friend has the gist of the bspi thing and configuring the MCU's EEPROM space will become hal parameters as part of this thing's component.
This is the pinout for hopefully what is the final firmware.
File Name: 7i92_BoB_p...r2.0.txt
File Size:2 KB
Moderators: PCW, jmelson
Time to create page: 0.387 seconds
