Question about custom BOB for a 7i92
3 years 5 months ago #271797 by blazini36
Replied by blazini36 on topic Question about custom BOB for a 7i92
If this is done at high speeds could a variable delay be sufficient?
I'm sure a variable delay would not be an issue, I'd think overall hardware delays would be greater than anything in the FPGA module. Delays themselves aren't really a major issue anyway as long as things happen reasonably fast which even the current setup seems fast enough , the biggest thing is the consistency of the overall cycle. If it took 300ns to do the whole thing the first time, doing it faster the 2nd time would actually be worse.
3 years 5 months ago #271798 by PCW
Replied by PCW on topic Question about custom BOB for a 7i92
What I was asking is could a variable time delay triggered by an input pin
accomplish your task? If so this is already supported in hardware
3 years 5 months ago #271801 by blazini36
Sorry I misunderstood. I think I get what you mean now. I assume that would look something like the velocity or encoder position of the roller controlling delay setting?....which actually sounds like it could work fairly reasonably as a simple way of doing it. That might actually work well for that test scenario but the real use is a bit more complicated. I wouldn't use that since I have a more flexible way of doing it with a hal component. Merging that hal logic into a firmware module would be the best way to do it but it works well enough even with the stackup of software and ethernet IO read/write variations.
I've been using that for several years, this guy actually tried something similar with LinuxCNC and a 7i76e then switched to using his own firmware on a DExx Nano (altera FPGA).
Fundamentally a similar thing to what I'm doing but you can see the difference between when he used a software implimentation vs full FPGA. I spoke to this guy a couple times, was curious why he didn't just try to write a hm2 module to do everything....he seemed to have the skill.
3 years 5 months ago #271850 by blazini36
PCW when you get a chance just let me know if that schematic usage an the pinout I posted yesterday jives so I can send that next rev out.
3 years 5 months ago #271889 by PCW
Looks OK to me
The following user(s) said Thank You: blazini36
3 years 5 months ago #271992 by blazini36
If just using 2 chips on BSPI, You just use 2 chip select pins and there is no frame pin right?
I just had the epiphany that I should probably just drop the 4 ADCs and use a 2nd 8bit MCU with analog inputs since I'm already in MCU land now.
Moderators: PCW, jmelson
Time to create page: 0.453 seconds
