Question about custom BOB for a 7i92
3 years 6 months ago - 3 years 6 months ago #270374 by PCW
Replied by PCW on topic Question about custom BOB for a 7i92
Note that you could use a '125 (active low enables)
instead of the '126 to eliminate the inverter
Also you have the input/output swapped on the buffers MISO signal
Last edit: 3 years 6 months ago by PCW.
3 years 6 months ago #270375 by blazini36
Replied by blazini36 on topic Question about custom BOB for a 7i92
Good catch, I just threw that together quick so I could try to understand the issue with the MISO buffer you mentioned and that symbol wasn't in the library.
good call on the '125 chip, I'll have to find some kind of resource for common ICs and their differences, like active low enables.
3 years 6 months ago #270376 by blazini36
Also, I don't know if bspi is using active high or low to enable the decoder. I have the active high in use on that sheet. I'm planning to use the pull down jumper on both headers if that matters.
I'm also using the non-inverted output of the HC251 chip assuming that's what InMux is looking for, is that correct?
3 years 6 months ago #270409 by PCW
I think the frame default is active low
(though can be inverted in the hal file)
On the 251 I would use the inverted output
as the default is also active low
3 years 5 months ago #270648 by blazini36
PCW, any word on that firmware?
3 years 5 months ago #270655 by PCW
Do you have a final pinout?
Moderators: PCW, jmelson
Time to create page: 0.512 seconds
