- Thank you received: 167
Question about custom BOB for a 7i92
- blazini36
3 years 6 months ago #269324
by blazini36
Replied by blazini36 on topic Question about custom BOB for a 7i92
1 more questions and I'm done for now, I promise lol.
Can the 7i92H be powered through the 26pin headers for 5V or must it be powered by the 2pin connector?
- Thank you received: 5334
3 years 6 months ago #269327
Replied by PCW on topic Question about custom BOB for a 7i92
You can backpower the 7I92 via its I/O connectors (make sure you use all 4 wires)
- blazini36
3 years 6 months ago #269514
by blazini36
I've got a 7i92th on the way, is there a mechanical drawing for the "h" version? Trying to get the pin headers lined up on my BOB but the manual shows the version with a DB25 in the 2nd position. Also, MOSI pin can be omitted from the pinfile if not in use right?
3 years 6 months ago #269520
You can drop the MOSI pin if the SPI devices do not require any data sent to them
(that is, they are read only devices and need only a clock and /CS to output date)
The following user(s) said Thank You: blazini36
- blazini36
3 years 6 months ago - 3 years 6 months ago #269959
by blazini36
This is the pinout I need the firmware for.
Hopefully I didn't make any mistakes. I ran out of IO so I had to use a decoder chip, SN74LVC1G139 for SPI CS lines.
Last edit: 3 years 6 months ago by blazini36. Reason: fix file
3 years 6 months ago - 3 years 6 months ago #270029
I'll try and get to this in the next few days.
Note your pinout is missing the CS frame pin
(this enables the external /CS decoder, otherwise there is no way to de-assert /CS)
You could gain 4 pins by using an inmux module for the 8 GPIO inputs
This needs a 74HC251 external mux and now 4 interface pins (A0,A1,A2 and D)
It also add hardware debouncing and 4 MPG encoders
Last edit: 3 years 6 months ago by PCW.
Time to create page: 0.287 seconds
