Light Machine Corp. Benchman XTr (retrofit)
- project-pegasus
- Visitor
8 years 4 months ago #112863
by project-pegasus
Replied by project-pegasus on topic Light Machine Corp. Benchman XTr (retrofit)
Yes, they will do a evaluation of the board for a pretty reasonable fee. They said they do have a working XT that they are able to test the ATC boards on. This is probably my next step.
- steve_a
8 years 3 months ago #113480
by steve_a
Replied by steve_a on topic Light Machine Corp. Benchman XTr (retrofit)
I replaced the controller in my BenchmanXT and have it working well. I have to manually change out the tool but that is not really a big deal. Still, I would like to use the ATC. Everything works. If I set up the spindle and the height, I can activate the pnuematics and change out a tool. Here's my problem. I have the spindle running on a velocity PID. How do I index it to accept the tool? I could just take the pin on the spindle out and just rely on the drawbar, but I'm not sure that's wise. Any suggestions?
Thanks!
Thanks!
8 years 3 months ago #113481
You need to switch to a different (position-mode) PID.
This diagram might clarify.
wiki.linuxcnc.org/uploads/orient.svg
(Ctrl + will make it bigger on most browsers)
Replied by andypugh on topic Light Machine Corp. Benchman XTr (retrofit)
steve_a wrote: I have the spindle running on a velocity PID. How do I index it to accept the tool?
- project-pegasus
- Visitor
8 years 3 months ago #114343
by project-pegasus
Well, I'm still trying to figure out what exactly the problem is with my ATC board and I think it may have something to do with the octal latches at U2 and U3. With the machine on and the program open the latch outputs are all floating between 1.8 to 2.5 VDC, even though the inputs are variously 0 or 5 VDC. When I open the ATC dialog box and try to move the platter down or unclamp the spindle I get the ATC command error message and the outputs on U2 all go to 5 VDC. Don, do you have any idea why it would be doing this?
- x-Intelitek Engineer
- Thank you received: 22
8 years 3 months ago #114403
by x-Intelitek Engineer
Replied by x-Intelitek Engineer on topic Light Machine Corp. Benchman XTr (retrofit)
Other then the outputs all going to +5V, it sounds like normal operation.
U2 and U3 outputs should be tri-stated until L_STAT signal "latches" the data and \RD_STATx becomes active and enables the outputs.
If you are getting the ATC command error, I suspect U10. You should be able to communicate fine. If you are communicating, the only error you should get is ATC in an unsafe state.
Looking back to your post of 6/22 with TP7 being active, I'm wondering if your wiring to J2 has Tx and Rx reversed.
Were you ever able to communicate to the ATC?
- project-pegasus
- Visitor
8 years 3 months ago #114436
by project-pegasus
I can rotate the platter through the ATC dialog box; if I select say tool # 5 it will rotate the platter to #5. So it seems like serial communication is fine, at least in the Tx direction. But as soon as I try to command the platter down the software freezes up and/or I get error messages about communication errors or ATC in unsafe position. I double checked the proximity sensors for the platter cylinders and they seem to be providing good data to U7 ( 0 or 5 VDC respectively). But at U2 things get weird. Like I stated above, the outputs are all similar regardless of the inputs, which are either 0 or 5 V, and when outputs are enabled they all go to 5V, even if their input is 0 V. Perhaps U2-11 never goes low to "latch" the input data, or it won't go high to unlatch bad data it received when the RN5 went bad. I guess I could monitor that and see what happens. Does the output enable or RD STAT originate at U4?
Time to create page: 0.157 seconds
