Light Machine Corp. Benchman XTr (retrofit)
8 years 2 days ago #119626 by steve_a
That's really interesting, but that would mean 7.5K cannot have a tool changer unless it has a different method to index the spindle. Were there toll changing models that ran at 7.5K?
  • x-Intelitek Engineer
  • Premium Member
  • Premium Member
8 years 2 days ago #119645 by x-Intelitek Engineer
Steve, you are correct. The 7.5K spindle used an external prox sensor to create the spindle home signal. Spindle Home is not spindle in position to do a toolchange, that is an offset from spindle home. The spindle home sensor is wired to J24 in a single control board Benchman, or J528 in the original multi-board configuration. I do not recall exactly what the sensor was detecting (flat or flag) on the spindle head.
7 years 7 months ago #128869 by james891
Replied by james891 on topic Light Machine Corp. Benchman XTr (retrofit)
Hi guys,
First time posting here. I just picked up a benchman XT as well with a connection problem. I think its the pc card, the company I bought it from said they couldnt fix the issue and I messed around with it with no luck. So I think I have the same problem almost everyone else has had.
I think I have to get a new controller which I am ok with, Id rather the machine run on more readily available parts. If I read these 35 pages correctly, scanning the relevant info, my best options options is to get a Mesa card and use that to communicate with the existing servo drives(copley), spindle(ultradrive) etc? Does anyone have better alternatives to get up and running asap besides paying $4-5000 for a used Nextmove card? Appreciate any feedback.
James
  • Premium Member
  • Premium Member
7 years 7 months ago #128891 by x-Intelitek Engineer
Replied by x-Intelitek Engineer on topic Light Machine Corp. Benchman XTr (retrofit)
James are you 100% sure that your problem is the Nextmove card? If so, then moving to another controller is your best bet.
If you are not 100% sure, I may be able to help you determine the issue. Please provide a photo of the main control card in the rear of the machine so I can determine your configuration.
7 years 7 months ago #129395 by james891
Thanks for the reply, if you have any tips, it would be much appreciated! I was told it worked, then the harddrive crashed, an employee there tried to reintall everything but couldnt get it working. Here are some pics:
drive.google.com/drive/folders/1VXEG9sKe...dqLoVEyZ?usp=sharing
I couldnt find device manager to set the right register, Im hoping the software included could do it. Otherwise Im not too sure what else to try...
  • project-pegasus
  • Visitor
  • Visitor
7 years 7 months ago #129399 by project-pegasus
Replied by project-pegasus on topic Light Machine Corp. Benchman XTr (retrofit)
My Nextmove card is a bit different than yours. Mine does not have the daughter board with those two cables going to the PCs I/O backplate. What was connected to those to cables? The card looks to be OK; you've got the right LEDs lit.
Time to create page: 0.688 seconds
