- Thank you received: 22
Light Machine Corp. Benchman XTr (retrofit)
- x-Intelitek Engineer
7 years 7 months ago #129780
by x-Intelitek Engineer
Replied by x-Intelitek Engineer on topic Light Machine Corp. Benchman XTr (retrofit)
I stand corrected.
Motherboards are available with ISA slots.
Thanks Andy!
Thanks Andy!
- 1996VMC4000
7 years 7 months ago #130112
by 1996VMC4000
Replied by 1996VMC4000 on topic Light Machine Corp. Benchman XTr (retrofit)
Apparently Intelitek no longer sells the 4th axis
jumper plug but did provide the attached jumper plug 32-5400-0386 wiring diagram.
The following user(s) said Thank You: james891
- james891
7 years 6 months ago #130119
by james891
Replied by james891 on topic Light Machine Corp. Benchman XTr (retrofit)
That's great thanks for the diagram! Would not having this cause the no connection error? I did a fresh NT install with no luck and now am on the hunt for a pentium 3 in my area.
- project-pegasus
- Visitor
7 years 3 months ago #139934
by project-pegasus
Replied by project-pegasus on topic Light Machine Corp. Benchman XTr (retrofit)
- project-pegasus
- Visitor
7 years 3 months ago #140362
by project-pegasus
7 years 3 months ago #140424
It has been a long time since I worked on a 4000. If you can give me the PCB numbers in the system, I may be able to help.
Time to create page: 0.466 seconds
