Light Machine Corp. Benchman XTr (retrofit)
  • x-Intelitek Engineer
  • Premium Member
  • Premium Member
8 years 1 week ago #119350 by x-Intelitek Engineer
Your spindle is the version that takes a custom straight shank toolholder. The hole you see is for a screw that secures the toolholder so that it cannot spin if the workload becomes heavy. The index for the spindle is inside the head of the spindle. I believe the index is a flat on the shaft. I wish I remember more, but my discipline is electrical. Intelitek should be able to help you. Are you still running the Intelitek S/W or moving to something else.
8 years 6 days ago #119430 by steve_a
OK, I dug into the bowels of the spindle head to try to determine why the sensor was not reading anything. I removed the sensor and examined the spindle it was closest to. I bench tested the sensor and found that it did not react to a ferric metal mass. For fun I tried a magnet and it DID react to that. However the spindle parts show no magnetism at all. Is there any possibility a magnet was at some point glued to the washer? Non of my findings make sense.
8 years 6 days ago - 8 years 6 days ago #119439 by andypugh
Possibly it is a sensor similar to this one in design:
www.allegromicro.com/~/media/Files/Datas...A9D70FB340EE44BA4F1E
And the internal magnet has been destroyed by heat.
It is probably not worth worrying about if the thread is M8 x 1 or another of the common proximity sensor sizes, just buy an inductive sensor from eBay that _will_ detect the spindle.
[edit] But make sure that you won't run up against any frequency / response-time limits.
Last edit: 8 years 6 days ago by andypugh.
The following user(s) said Thank You: steve_a
  • Premium Member
  • Premium Member
8 years 6 days ago #119442 by x-Intelitek Engineer
Thinking about it some more, I believe that is the drawbar sensor and not the spindle index sensor. The drawbar sensor is to ensure that the spindle cannot turn while the drawbar is open. The spindle index sensor is part of the spindle encoder connection to the speed control.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
8 years 5 days ago #119491 by steve_a
OK, That makes all kinds of sense now! That being said I think the encoder is attached to the back of the motor so that means the ratio must be 1:1 to be able to accurately index the spindle. I'll have to see if I can access the wires and throw a meter on them. Wow this is going to be a complicated series of moves. Well at least I have a direction to try. THANKS ALL!
  • Premium Member
  • Premium Member
8 years 3 days ago #119591 by x-Intelitek Engineer
It may be 1:1, if your spindle is 5K it is 1:1, if you have a 7.5K spindle, it is belt driven and it becomes 1.5:1.
Time to create page: 0.393 seconds
