Brother TC-211
12 years 3 months ago #48792 by PCW
Replied by PCW on topic Brother TC-211
I would not expect a battery on the drive analog inputs to
drive the motor unless the drive was enabled.
AFAICT from the manual, the drive is enabled by shorting CN8-15 to CN8-16
12 years 3 months ago #48824 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
Went back and jumped pin 15 and 16, applied power nothing still. Any more ideas.
12 years 3 months ago #48826 by PCW
I would back to the Brother controller and measure all I/O pin voltages on
CN8 when its operating to figure out what the drive needs to be enabled
12 years 3 months ago #48827 by mblaszkiewicz
Ill work on it tommorow
12 years 3 months ago - 12 years 3 months ago #48907 by mblaszkiewicz
Ok got some interesting numbers. Pin 1 to 2 was the voltage desired. All Ok there
pin 17 to 18 was continuity at all times.
The word one was pins 14 15 and 16
14 to 16 was 22.5 volts
pins 14 to 15 caused a fault and trip thru my meter.
So how do I get the voltage to pins 14 and 16 thru the card and in the future how would I configure it
Last edit: 12 years 3 months ago by mblaszkiewicz.
12 years 3 months ago #48909 by PCW
You should be able to measure between 14 and 15 without causing a fault
but make sure the meter is in voltage mode
do not ever use Ohm range or continuity test when power is applied
Time to create page: 0.244 seconds
