Brother TC-211
12 years 6 months ago #45538 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
It is a full functioning machine with a brother conversational control. As soon as I get some of the manual scanned I will post it here. Only 480 more pages to go :)
12 years 6 months ago #45561 by mblaszkiewicz
Since this is a low hp machine. 1.5 hp spindle. Is it possible to run the whole machine on a static phase Converter in the three to five hp range? Also any advice on how to start on tHis project cards etc would be helpful
12 years 6 months ago #45563 by andypugh
Replied by andypugh on topic Brother TC-211
mblaszkiewicz wrote: Since this is a low hp machine. 1.5 hp spindle. Is it possible to run the whole machine on a static phase Converter in the three to five hp range?
Quite possibly. Have you checked that the input transformer isn't configurable for your mains voltage?
(What is your mains voltage?)
We can't really advise until we know what the control signals are from controller to drives. (and the other way too)
12 years 6 months ago - 12 years 6 months ago #45595 by mblaszkiewicz
Machine is finally off the truck :)
The power is 230 3 phase.
I am looking in the manual for how the controller talks to the servos. I will get back with the info asap
image missing http://i1357.photobucket.com/albums/q757/mblaszkiewicz/20140405_1125551_zpsa867cffb.jpg
Last edit: 12 years 6 months ago by mblaszkiewicz.
12 years 6 months ago #45597 by mblaszkiewicz
I'm not sure if this is the needed info for the controller/servo. if not let me know, and a clue as to what I am looking for
i1357.photobucket.com/albums/q757/mblasz...0271_zpsa2fbf373.jpg
12 years 6 months ago #45598 by emcPT
Replied by emcPT on topic Brother TC-211
It seams that your drives accept +-10V analog signals.
If the drives are in working conditions the retrofit will not be expensive or too much hard (well it will be easier)
I would recommend a 5i25 + 7i77 for the control of the servo motors. Probably a 7i74 and a 7i84 will be needed after if a lot of IO is needed (if you want to maintain the control with physical buttons, that I personally like).
Time to create page: 0.323 seconds
