- Thank you received: 4
Good point. It takes up less space, but that is more relevant in a hand-held pendant than a machine console.emcPT wrote: The 7i73 is harder to connect. The use of the IDC connectors make the connections more difficult and less user friendly.
The drives probably only work with resolvers though, so that swap would need new drives.emcPT wrote: Swapping your resolvers for compatible encoders should also not be a large issue if your current resolvers do not work.
andypugh wrote: The drives probably only work with resolvers though, so that swap would need new drives.
