- Thank you received: 4
emcPT wrote: It seams that your drives accept +-10V analog signals.
If the drives are in working conditions the retrofit will not be expensive or too much hard (well it will be easier).
mblaszkiewicz wrote: Thanks its a start. Now a newbie question. What do all the cards do.
andypugh wrote: For wiring up the control panel a 7i73 might be better. (as it has MPG inputs and supports matrix-wired switches). Cheap too.
