HAAS VF1 retrofit
- sspeed33317
12 Aug 2014 23:46 - 12 Aug 2014 23:48 #49769
by sspeed33317
Replied by sspeed33317 on topic HAAS VF1 retrofit
Shuttle and Carousel motor get their power from servo motor power supply 160vdc
which is supplied to the I/O board , controlled by forward and reverse relays for each.
I did notice resistors in the circuit , probably to limit current or provide a voltage drop.
the motors themselves say 130vdc.
The carousel is a gear motor/geneva
The shuttle is sort of like a arm type window lift mechanism in your car. Also has a slip clutch in the mix.
Last edit: 12 Aug 2014 23:48 by sspeed33317.
- sspeed33317
12 Aug 2014 23:51 #49770
by sspeed33317
How about adding a second prox switch to the tool position pulse, that would give it a B phase??
I have to look but it may be just a matter of machining another hole in the bracket.
13 Aug 2014 00:16 #49772
If you can do that it would probably be more reliable. But the LUT5 way sounds like fun too
Replied by andypugh on topic HAAS VF1 retrofit
- sspeed33317
13 Aug 2014 07:48 #49790
by sspeed33317
My brain hurts
- sspeed33317
14 Aug 2014 08:25 #49839
by sspeed33317
Just throwing this out there....
Is it possible to jump in and out of classic ladder?
For example,
tool change is called,
Z axis moves to tool change height.
Here we jump into classic ladder.. shuttle moves in and releases draw bar.
Back out of classic ladder, Z moves to tool change safe height.
Back into classic ladder, carousel finds new tool position.
Out of classic ladder, Z moves back to tool change height.
Back into classic ladder and clamp draw bar and shuttle out. Tool change completed.
For example,
- sspeed33317
14 Aug 2014 11:50 - 14 Aug 2014 11:57 #49841
by sspeed33317
ok, i know how i am going to do the carousel
Going to do it with grey code, then I dont have to worry about homing it.
20 positions of grey code ,and bit driven by the carousel drive pin
This way it stops in the correct place and doesnt overshoot.
The switch on the drive pin will be the last to trip and will have a wiper to compensate for motor coast down.
I found a component for a lathe turret with grey code and it should work for me with some modifications.
Last edit: 14 Aug 2014 11:57 by sspeed33317.
- sspeed33317
21 Aug 2014 09:24 #50127
by sspeed33317
I'm still here.
I built the panel for the 7i77 this past weekend. Mounted some din rail and about a dozen relays.
The servo amp and power panel is almost ready, bought some inrush limiters to put on the caps.
The computer panel seems to be stable.
Replaced the original 30 amp three phase breaker with a 60 amp single phase breaker and reused the operator mechanism.
Bought some shielded wire.
5v 24v logic power supply
And got a great deal on a new VFD
So I should be ready to wire this thing up this weekend.
And I am looking forward to seeing what Tkamsker came up with.
- Zahnrad Kopf
21 Aug 2014 17:28 #50139
by Zahnrad Kopf
Replied by Zahnrad Kopf on topic HAAS VF1 retrofit
I've been following your thread. Really looking forward to seeing your progress.
- sspeed33317
22 Aug 2014 00:31 #50155
by sspeed33317
Almost lost all of my photos, my SD card fell out of my phone , but I was lucky to find it.
- xylotex
22 Aug 2014 01:48 #50156
by xylotex
Replied by xylotex on topic HAAS VF1 retrofit
During clamping of the tool on the original Haas machine, the drawbar will end up pulling the tool up in to the spindle. To compensate for this upward motion of the tool, the Z axis moves down a small amount during the clamping process (I think the reverse is also true during unclamping). This is parameter 71 and 72 IIRC. If you don't include something like this you might be putting extra stress on the carousel and holding fingers. Not sure if it is enough to really worry about, but it was there in the original Haas machine configuration.
When you get things going, do a manual tool change/release. You will be able to see how much motion there will be in the tool as it gets drawn in to the spindle.
Jeff
Jeff
The following user(s) said Thank You: sspeed33317
Time to create page: 0.382 seconds
