Planning - Bridgeport Interact 1 linuxCNC Retrofit
10 years 9 months ago #68464 by csbrady
Yes, I just figured out the problem last night. It was my measurement setup.
I set my index pulse for 90 degrees. As far as I can tell both will work, but I think 90 degrees is more standard.
10 years 9 months ago #68470 by PCW
BTW it is suggested that you _do not_ reverse the output polarity by changing the PID signs
The PID component has a nasty bug with integral limits and negative parameters...
If your input scale is correct (encoders read in the right direction), and you have feedback backwards (runaway),
the easiest way to reverse the output polarity on a 7I77 is to change the sign of the scalemax parameter
10 years 9 months ago - 10 years 9 months ago #68486 by cncnoob1979
PCW,
Is the scalemax parameter located in the INI file?
Im looking in the linuxcnc documents under INI and I don't see it listed.
LinuxCnc INI Documentation
Last edit: 10 years 9 months ago by cncnoob1979.
10 years 9 months ago #68487 by csbrady
If you were running away with positive PID values then reversing either the encoder or the servos is needed but not both. Most likely you will only need to reverse the encoders. At least that is what I found.
10 years 9 months ago #68488 by PCW
look like its:
OUTPUT_SCALE = 10
in the pncconf created .ini file
You should be able to see where the mumble.mumble.scalemax
parameters are initialized by looking at the HAL file
Note that many INI names are arbitrary so you could have a INI file entry:
[AXIS_0]
FOONBLATS_PER_SPUD = 100.0
and then in your HAL file:
setp foonblats.0 [AXIS_0]FOONBLATS_PER_SPUD
so dont expect all INI file parameters to be documented...
10 years 9 months ago - 10 years 9 months ago #68547 by cncnoob1979
Thanks guys!
I have the machine testing pretty well. Tuning servos was a very steep learning curve. The more I find out what I don't know, the more I don't know! lol
Here is a video of where I have all 3 tuned to. Can't seem to get the overshoot sorted. I ended up with zero ff2/I/D
I tried many different combos. I'm sure I'll try again. My garage is a mess so you just get the monitor screen playing halscope!
Edit: btw, this was at 60in/min.
Thanks for all the help so far! I'm going to need more! :laugh:
Tuning servos
Time to create page: 0.405 seconds
