Planning - Bridgeport Interact 1 linuxCNC Retrofit
10 years 9 months ago #68835 by csbrady
I have the original velocity parameters for the Machine that were set in the TNC 151.
Rapid Trav X,Y 197
Rapid Trav Z 157
Man Feed XYZ 20
I set my max velocity a little less than these, 190 and 150. No need to stress the machine. I could not find any indication of what the original max acceleration was. Having used the machine a lot I suspect that it was around 8. My setting of 4 is clearly more sluggish. The default of 20 was much higher than the original and made the machine jerky and sounded bad.
Here are a few more parameters that you may find useful:
Backlash Comp X 0.000472
Backlash Comp Y 00.00098
Backlash Comp Z 0
X Range + -17.75587
Y Range + -11.708638
Z Range + -4.665345
X Range - 0.240157
Y Range - 0.303149
Z Range - 0.259842
I readjusted all of these but it was nice to have a starting place.
The following user(s) said Thank You: cncnoob1979
10 years 9 months ago #68836 by Todd Zuercher
I doubt the factory precision of the machine was much if any better than that.
10 years 9 months ago - 10 years 9 months ago #68845 by csbrady
Todd, I agree this is probably as good and possibly better than the factory precision. It's also better than I actually need since neither my skills or projects are "high precision". But that does not keep me from a neurotic quest to make it better. I am a hobbyist after all. :silly:
Last edit: 10 years 9 months ago by csbrady.
10 years 9 months ago #68899 by cncnoob1979
csbrady,
Would you mind posting your final INI and HAL files for me to look at? I would like to see how you linked everything together with your panel ect.
Reading yours helps me understand the links between each file/pin.
Also I like comparing yours to mine. :)
10 years 9 months ago #69004 by csbrady
Here are my hal and ini files.
Good luck!
File Name: bertha.hal
File Size:20.38 KB
File Name: bertha.ini
File Size:3.59 KB
10 years 9 months ago - 10 years 9 months ago #69234 by cncnoob1979
csbrady,
Thanks for the files! They really help me understand my HAL and INI files.
Here is a video of my spindle running, as well as my mess in the garage. I'm using the cheap 3KW China VFD. I removed the 4MR contactor because one of the contact points fell off! So yeah, it was bad. I tried to remove just the wires and move them to the other contactor. I failed and now I have to trace each wire down again. Anyway...
Just a bit more progress!
Last edit: 10 years 9 months ago by cncnoob1979.
Time to create page: 0.410 seconds
