csbrady,
Hey! Thanks for the response, I know you have to be scratching you head on my approach. The reason I want to do it this way is because:
Not using the VFD speed control reasons:
1) Using the system as it was designed. I also have a working speed setup with the pneumatic speed rotary controlled via 7i77, and manual switches.
2) I do not have to worry about torque curves or limitations associated with our variable system.
3) I do not have to worry about cooling of the motor/over stressing the motor via exceeding 60hz (over or under)
4) With variable speed, I am not at 1:1 ratio, therefore without a spindle encoder, I do not know what my true spindle speed is.
5) Without the true spindle speed it would be difficult to provide the proper feeds/speeds
Using the VFD with modbus speed control Positives:
1) Control with G-Code
2) easier to implement.
3) Just plain ass cool
:lol: lol
Honestly I would prefer it to be setup where I need to manually move the RPMs to meet my speed/feeds setup, However I may find it is extremely difficult to implement or impossible. So I may just go with speed control via MODBUS. However with the speed implementation I would have to set a scale factor and I would need to figure out the ratios to do so. It can be done of course but, I do like to go about things the hard-way it would seem!
Unless I'm thinking about this all wrong - which Ive been known to do, then perhaps you could explain it to me so I understand? Where do you have your RPMs manually set at? How do you know what spindle speed you are at?
My motor is the same as yours, 1735 designed rpm's. Are you pushing yours over 60hz, if so what limit have you set for it?
EDIT: csbrady, Im guessing you set your spindle RPM's for 1735. Which would make that a 1:1 ratio. Man cant believe I didn't think of that till just now! :blink:
Well then... So what is your lower Hz limit and your uppper Hz limit?
Also, using an old HDMI cable for MODBUS - awesomeness!
image missing http://i346.photobucket.com/albums/p431/swill008/2015-11/495122EA-FB11-457B-9979-7F32BB650A30_zpsqtkpkttd.jpg
image missing http://i346.photobucket.com/albums/p431/swill008/2015-11/559E7790-1F4B-4DCE-BA8A-A7177CF768B4_zpsumze4qub.jpg
