- Thank you received: 75
Does the switch indicate three distinct states? If it doesn't then it can't be done.cncnoob1979 wrote: CI'm trying to use a 3 position switch to select each axis; X Y Z to enable jogging to that axis. The catch is... it a single throw 2 NO switch. I cant seem to find an instance of this anywhere. I can only send two signals, one to y and one to z, ideally I would need to send 3 signals.
I have done almost no engraving. When I engraved a scale-ring I wrote some G-code by hand:what program do you use for engraving?
